hi,
I have a example set with an attribute labeling the examples into different bins (eg: 1,2,3,.., 10) and now I want to divide my dataset into 10 subsets according to the bin index. I try to use the Groupby operator but the result example set is the same as the original. I also tried to use the splittedexmapleset function but still got the same result. Anything suggestions? Thank you for any help!
Best Regards
