To cover my butt, I have searched both these forums on the web via google for the answer
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="161" width="346"> <operator activated="true" class="generate_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Data" width="90" x="59" y="89"/> <operator activated="true" class="filter_examples" compatibility="5.0.10" expanded="true" height="76" name="Filter Examples" width="90" x="246" y="75"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label<0.5"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
