<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="431" width="614"> <operator activated="true" class="subprocess" compatibility="5.0.10" expanded="true" height="76" name="first dataset" width="90" x="45" y="30"> <process expanded="true" height="404" width="532"> <operator activated="true" class="generate_nominal_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Nominal Data" width="90" x="112" y="30"/> <operator activated="true" class="nominal_to_binominal" compatibility="5.0.10" expanded="true" height="94" name="Nominal to Binominal" width="90" x="246" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.0.10" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="subprocess" compatibility="5.0.10" expanded="true" height="76" name="second dataset" width="90" x="45" y="165"> <process expanded="true" height="404" width="550"> <operator activated="true" class="generate_nominal_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Nominal Data (2)" width="90" x="45" y="75"/> <operator activated="true" class="replace" compatibility="5.0.10" expanded="true" height="76" name="Replace" width="90" x="112" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="negative"/> <parameter key="replace_by" value="no"/> </operator> <operator activated="true" class="replace" compatibility="5.0.10" expanded="true" height="76" name="Replace (2)" width="90" x="246" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="positive"/> <parameter key="replace_by" value="yes"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.0.10" expanded="true" height="94" name="Nominal to Binominal (2)" width="90" x="313" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="Generate Nominal Data (2)" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Replace (2)" to_port="example set input"/> <connect from_op="Replace (2)" from_port="example set output" to_op="Nominal to Binominal (2)" to_port="example set input"/> <connect from_op="Nominal to Binominal (2)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="18"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.0.10" expanded="true" height="76" name="Nominal to Text (2)" width="90" x="179" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="append" compatibility="5.0.10" expanded="true" height="94" name="Append" width="90" x="313" y="120"/> <operator activated="true" class="text_to_nominal" compatibility="5.0.10" expanded="true" height="76" name="Text to Nominal" width="90" x="447" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="first dataset" from_port="out 1" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Append" to_port="example set 1"/> <connect from_op="second dataset" from_port="out 1" to_op="Nominal to Text (2)" to_port="example set input"/> <connect from_op="Nominal to Text (2)" from_port="example set output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Text to Nominal" to_port="example set input"/> <connect from_op="Text to Nominal" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="386" width="832"> <operator activated="true" class="loop" compatibility="5.0.10" expanded="true" height="60" name="Write CSVs" width="90" x="45" y="30"> <parameter key="iterations" value="3"/> <process expanded="true" height="376" width="850"> <operator activated="true" class="generate_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Data" width="90" x="57" y="26"/> <operator activated="true" class="discretize_by_bins" compatibility="5.0.10" expanded="true" height="94" name="Discretize" width="90" x="217" y="28"> <parameter key="create_view" value="true"/> <parameter key="range_name_type" value="short"/> </operator> <operator activated="true" class="write_constructions" compatibility="5.0.10" expanded="true" height="60" name="Write Constructions" width="90" x="376" y="138"> <parameter key="attribute_constructions_file" value="atts"/> </operator> <operator activated="true" class="replace" compatibility="5.0.10" expanded="true" height="76" name="Replace" width="90" x="380" y="30"> <parameter key="replace_what" value="range"/> <parameter key="replace_by" value="run_%{a}"/> </operator> <operator activated="true" class="write_csv" compatibility="5.0.10" expanded="true" height="60" name="Write CSV" width="90" x="543" y="26"> <parameter key="csv_file" value="gagi_%{a}"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Replace" to_port="example set input"/> <connect from_op="Discretize" from_port="original" to_op="Write Constructions" to_port="input"/> <connect from_op="Replace" from_port="example set output" to_op="Write CSV" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <operator activated="true" class="loop" compatibility="5.0.10" expanded="true" height="76" name="Read CSVs" width="90" x="45" y="165"> <parameter key="iterations" value="3"/> <process expanded="true" height="376" width="850"> <operator activated="true" class="read_csv" compatibility="5.0.10" expanded="true" height="60" name="Read CSV" width="90" x="112" y="75"> <parameter key="file_name" value="gagi_%{a}"/> <list key="data_set_meta_data_information"/> </operator> <connect from_op="Read CSV" from_port="output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.0.10" expanded="true" height="76" name="Append" width="90" x="179" y="165"/> <operator activated="true" class="write_csv" compatibility="5.0.10" expanded="true" height="60" name="Write Merged" width="90" x="313" y="165"> <parameter key="csv_file" value="merged"/> <parameter key="write_attribute_names" value="false"/> </operator> <operator activated="true" class="read_csv" compatibility="5.0.10" expanded="true" height="60" name="Read Merged" width="90" x="45" y="300"> <parameter key="file_name" value="merged"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.0.10" expanded="true" height="76" name="Tidy up" width="90" x="246" y="300"> <parameter key="condition_class" value="no_missing_attributes"/> </operator> <connect from_op="Read CSVs" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Write Merged" to_port="input"/> <connect from_op="Read Merged" from_port="output" to_op="Tidy up" to_port="example set input"/> <connect from_op="Tidy up" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="386" width="832"> <operator activated="true" class="loop" compatibility="5.0.10" expanded="true" height="60" name="Write CSVs" width="90" x="45" y="30"> <parameter key="iterations" value="3"/> <process expanded="true" height="376" width="850"> <operator activated="true" class="generate_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Data" width="90" x="57" y="26"/> <operator activated="true" class="discretize_by_bins" compatibility="5.0.10" expanded="true" height="94" name="Discretize" width="90" x="217" y="28"> <parameter key="create_view" value="true"/> <parameter key="range_name_type" value="short"/> </operator> <operator activated="true" class="write_constructions" compatibility="5.0.10" expanded="true" height="60" name="Write Constructions" width="90" x="376" y="138"> <parameter key="attribute_constructions_file" value="atts"/> </operator> <operator activated="true" class="replace" compatibility="5.0.10" expanded="true" height="76" name="Replace" width="90" x="380" y="30"> <parameter key="replace_what" value="range"/> <parameter key="replace_by" value="run_%{a}"/> </operator> <operator activated="true" class="write_csv" compatibility="5.0.10" expanded="true" height="60" name="Write CSV" width="90" x="543" y="26"> <parameter key="csv_file" value="gagi_%{a}"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Replace" to_port="example set input"/> <connect from_op="Discretize" from_port="original" to_op="Write Constructions" to_port="input"/> <connect from_op="Replace" from_port="example set output" to_op="Write CSV" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <operator activated="true" class="loop" compatibility="5.0.10" expanded="true" height="76" name="Read CSVs" width="90" x="45" y="165"> <parameter key="iterations" value="3"/> <process expanded="true" height="376" width="850"> <operator activated="true" class="read_csv" compatibility="5.0.10" expanded="true" height="60" name="Read CSV" width="90" x="112" y="75"> <parameter key="file_name" value="gagi_%{a}"/> <parameter key="use_first_row_as_attribute_names" value="false"/> <list key="data_set_meta_data_information"/> </operator> <connect from_op="Read CSV" from_port="output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.0.10" expanded="true" height="76" name="Append" width="90" x="179" y="165"/> <operator activated="true" class="write_csv" compatibility="5.0.10" expanded="true" height="60" name="Write Merged" width="90" x="313" y="165"> <parameter key="csv_file" value="merged"/> <parameter key="write_attribute_names" value="false"/> </operator> <operator activated="true" class="read_csv" compatibility="5.0.10" expanded="true" height="60" name="Read Merged" width="90" x="45" y="300"> <parameter key="file_name" value="merged"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.0.10" expanded="true" height="76" name="Tidy up" width="90" x="246" y="300"> <parameter key="condition_class" value="no_missing_attributes"/> </operator> <connect from_op="Read CSVs" from_port="output 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_op="Write Merged" to_port="input"/> <connect from_op="Read Merged" from_port="output" to_op="Tidy up" to_port="example set input"/> <connect from_op="Tidy up" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
