Hi, how can i add point or marker on curve at specific X value?
Hi Jakub,
Do you want to add a point on an existing curve?
You can actually create a curve or point using Define Curves panel in HyperGraph.
Yes, I want to add point on existing curve
could you write with detail how to create point on existing curve?
It may not be possible to add points in extisting curve. But you can add a new curve or points.
as a work around, export the curve as a csv file and add points in the same csv file. Goto Export>>export curves to export to csv/text format.
Import the same file back in HyperGraph.
