Memory Overflow
User: "MuehliMan"
New Altair Community Member
Updated by Jocelyn
My process is either freezing my PC or failing due to low memory. Unfortunately my dataset consists of 700 attributes, so the amount of data is really large.Therefore I already log only the top 200 models and I also free memory after every iteration. Any suggestions why it is still not running properly?
Thanks a lot in advance,
Markus
<process version="5.0">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.0.0" expanded="true" name="Process">
    <process expanded="true" height="449" width="1150">
      <operator activated="true" class="generate_data" compatibility="5.0.0" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
        <parameter key="target_function" value="polynomial"/>
        <parameter key="number_examples" value="300"/>
        <parameter key="number_of_attributes" value="700"/>
      <operator activated="true" class="add_noise" compatibility="5.0.0" expanded="true" height="94" name="Add Noise" width="90" x="179" y="30">
        <parameter key="random_attributes" value="15"/>
        <list key="noise"/>
      <operator activated="true" class="discretize_by_user_specification" compatibility="5.0.0" expanded="true" height="94" name="Discretize" width="90" x="313" y="30">
        <parameter key="attribute" value="label"/>
        <list key="classes">
          <parameter key="first" value="0.5"/>
          <parameter key="last" value="Infinity"/>
        </list>
      <operator activated="true" class="nominal_to_binominal" compatibility="5.0.0" expanded="true" height="94" name="Nominal to Binominal" width="90" x="447" y="30">
      <operator activated="true" class="loop_attribute_subsets" compatibility="5.0.0" expanded="true" height="60" name="Loop Subsets" width="90" x="581" y="30">
        <parameter key="use_exact_number" value="true"/>
        <parameter key="exact_number_of_attributes" value="2"/>
        <process expanded="true" height="372" width="817">
          <operator activated="true" class="multiply" compatibility="5.0.0" expanded="true" height="94" name="Multiply" width="90" x="45" y="30"/>
          <operator activated="false" class="x_validation" compatibility="5.0.0" expanded="true" height="112" name="Validation" width="90" x="179" y="165">
            <parameter key="number_of_validations" value="5"/>
            <process expanded="true" height="390" width="303">
              <operator activated="false" class="decision_tree" compatibility="5.0.0" expanded="true" height="76" name="Decision Tree" width="90" x="112" y="30">
                <parameter key="criterion" value="gini_index"/>
                <parameter key="minimal_size_for_split" value="6"/>
                <parameter key="minimal_leaf_size" value="3"/>
                <parameter key="maximal_depth" value="4"/>
              <connect from_port="training" to_op="Decision Tree" to_port="training set"/>
              <connect from_op="Decision Tree" from_port="model" to_port="model"/>
              <portSpacing port="source_training" spacing="0"/>
            </process>
              <operator activated="false" class="apply_model" compatibility="5.0.0" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
              <operator activated="false" class="performance_binominal_classification" compatibility="5.0.0" expanded="true" height="76" name="Performance" width="90" x="174" y="30">
                <parameter key="youden" value="true"/>
                <parameter key="psep" value="true"/>
              <connect from_port="model" to_op="Apply Model" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
              <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
              <portSpacing port="sink_averagable 1" spacing="0"/>
              <portSpacing port="sink_averagable 2" spacing="0"/>
            </process>
          <operator activated="true" class="decision_tree" compatibility="5.0.0" expanded="true" height="76" name="Decision Tree (2)" width="90" x="179" y="30">
            <parameter key="maximal_depth" value="5"/>
          <operator activated="true" class="apply_model" compatibility="5.0.0" expanded="true" height="76" name="Apply Model (2)" width="90" x="313" y="30">
          <operator activated="true" class="performance_binominal_classification" compatibility="5.0.0" expanded="true" height="76" name="Performance (2)" width="90" x="447" y="30">
          <operator activated="true" class="log" compatibility="5.0.0" expanded="true" height="94" name="Log" width="90" x="581" y="30">
            <list key="log">
              <parameter key="feature_names" value="operator.Loop Subsets.value.feature_names"/>
              <parameter key="youden" value="operator.Performance (2).value.youden"/>
              <parameter key="accuracy" value="operator.Performance (2).value.accuracy"/>
            </list>
            <parameter key="sorting_type" value="top-k"/>
            <parameter key="sorting_dimension" value="youden"/>
            <parameter key="sorting_k" value="200"/>
          <operator activated="true" class="free_memory" compatibility="5.0.0" expanded="true" height="76" name="Free Memory" width="90" x="717" y="30"/>
          <connect from_port="example set" to_op="Multiply" to_port="input"/>
          <connect from_op="Multiply" from_port="output 1" to_op="Decision Tree (2)" to_port="training set"/>
          <connect from_op="Multiply" from_port="output 2" to_op="Log" to_port="through 2"/>
          <connect from_op="Decision Tree (2)" from_port="model" to_op="Apply Model (2)" to_port="model"/>
          <connect from_op="Decision Tree (2)" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/>
          <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
          <connect from_op="Performance (2)" from_port="performance" to_op="Log" to_port="through 1"/>
          <connect from_op="Log" from_port="through 1" to_op="Free Memory" to_port="through 1"/>
        </process>
      <operator activated="true" class="log_to_data" compatibility="5.0.0" expanded="true" height="94" name="Log to Data" width="90" x="715" y="30"/>
      <operator activated="true" class="store" compatibility="5.0.0" expanded="true" height="60" name="Store" width="90" x="849" y="30">
        <parameter key="repository_entry" value="../Logs/Training DT 2 atts"/>
      <operator activated="true" class="log_to_weights" compatibility="5.0.10" expanded="true" height="60" name="Log to Weights" width="90" x="849" y="120">
        <parameter key="attribute_names_column" value="feature_names"/>
      <operator activated="true" class="store" compatibility="5.0.10" expanded="true" height="60" name="Store (2)" width="90" x="983" y="120">
        <parameter key="repository_entry" value="../weights/Training DT 2 atts"/>
      <connect from_op="Generate Data" from_port="output" to_op="Add Noise" to_port="example set input"/>
      <connect from_op="Add Noise" from_port="example set output" to_op="Discretize" to_port="example set input"/>
      <connect from_op="Discretize" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/>
      <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Loop Subsets" to_port="example set"/>
      <connect from_op="Loop Subsets" from_port="example set" to_op="Log to Data" to_port="through 1"/>
      <connect from_op="Log to Data" from_port="exampleSet" to_op="Store" to_port="input"/>
      <connect from_op="Log to Weights" from_port="weights" to_op="Store (2)" to_port="input"/>
    </process>
</process>
