<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="391" width="957"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="47" y="46"/> <operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="94" name="Multiply" width="90" x="179" y="75"/> <operator activated="true" class="sort" compatibility="5.0.8" expanded="true" height="76" name="Sort (2)" width="90" x="380" y="120"> <parameter key="attribute_name" value="att1"/> <parameter key="sorting_direction" value="decreasing"/> </operator> <operator activated="true" class="filter_example_range" compatibility="5.0.8" expanded="true" height="76" name="Filter Example Range (2)" width="90" x="514" y="120"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="10"/> </operator> <operator activated="true" class="sort" compatibility="5.0.8" expanded="true" height="76" name="Sort" width="90" x="380" y="30"> <parameter key="attribute_name" value="att1"/> </operator> <operator activated="true" class="filter_example_range" compatibility="5.0.8" expanded="true" height="76" name="Filter Example Range" width="90" x="514" y="30"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="10"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Sort" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Sort (2)" to_port="example set input"/> <connect from_op="Sort (2)" from_port="example set output" to_op="Filter Example Range (2)" to_port="example set input"/> <connect from_op="Filter Example Range (2)" from_port="example set output" to_port="result 2"/> <connect from_op="Sort" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
