I am new to RapidMiner (I work with it since yesterday) and I am trying to integrate it in my bachelor project.
The problem is the following: when I add the RapidMiner project and when I call the init() method, absolutely nothing appears on the console - neither the RapidMiner intialization messages, nor my own output, no matter where I have put it.
public static void main(String[] args) throws Exception {
System.out.println("Hi!");
LogService.getGlobal().setVerbosityLevel(LogService.MAXIMUM);
RapidMiner.init();
String file = "E:\\Java\\workspace\\Diplomarbeit\\ethnicity_query.xml";
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
Set<Example> results = new HashSet<Example>();
File xml = new File(file);
try {
Process process = new Process(xml);
IOContainer container = process.run();
ExampleSet exampleSet = container.get(ExampleSet.class);
Iterator<Example> iteratorExample = exampleSet.iterator();
while (iteratorExample.hasNext()) {
Example example = iteratorExample.next();
results.add(example);
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
} catch (XMLException e) {
} catch (OperatorException e) {
System.out.println(results.size());
This code prodices a blank console. Any ideas what might be causing it?
Thanks,
Drago
P.S. I am using Eclipse 3.6 Helios
