<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="161" width="547"> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="112" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="loop_attribute_subsets" compatibility="5.0.8" expanded="true" height="60" name="Loop Subsets" width="90" x="246" y="30"> <process expanded="true" height="391" width="975"> <operator activated="true" class="subprocess" compatibility="5.0.8" expanded="true" height="76" name="Do Something" width="90" x="45" y="30"> <process expanded="true"> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.0.8" expanded="true" height="76" name="Log" width="90" x="179" y="30"> <list key="log"> <parameter key="Iteration" value="operator.Loop Subsets.value.iteration"/> <parameter key="Number Of Attributes" value="operator.Loop Subsets.value.feature_number"/> <parameter key="Attributes" value="operator.Loop Subsets.value.feature_names"/> </list> </operator> <connect from_port="example set" to_op="Do Something" to_port="in 1"/> <connect from_op="Do Something" from_port="out 1" to_op="Log" to_port="through 1"/> <portSpacing port="source_example set" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Loop Subsets" to_port="example set"/> <connect from_op="Loop Subsets" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
