C:\Program Files\Rapid-I\RapidMiner5\scripts>C:\Program Files\Rapid-I\RapidMiner5\scripts>rapidminer com.rapidminer.RapidMinerCommandLine -f C:\Users\wessel\Documents\RMDEFAULT\new.rmpRAPIDMINER_HOME is not set. Trying the directory 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'...Using local jre: C:\Program Files\Rapid-I\RapidMiner5\scripts\..\jre\bin\java.exe...Starting RapidMiner from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..' using classes from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..\lib\rapidminer.jar'...RapidMiner version 5.0.010, Copyright (C) 2001-2008RapidMiner comes with ABSOLUTELY NO WARRANTY; This is free software,and you are welcome to redistribute it under certain conditions;see license information in the file named LICENSE.4-sep-2010 14:19:32 com.rapid_i.Launcher ensureRapidMinerHomeSetINFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'.2010-09-04 14:19:33 CONFIG: Locale not specified explicitly. Set default localeto US. (RapidMiner.init())2010-09-04 14:19:33 CONFIG: Initializing I18N (RapidMiner.splashMessage())2010-09-04 14:19:33 CONFIG: Ensuring RapidMiner Home is set (RapidMiner.splashMessage())2010-09-04 14:19:33 INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'. (Launcher.ensureRapidMinerHomeSet())2010-09-04 14:19:33 CONFIG: Reading Configuration Files (RapidMiner.splashMessage())2010-09-04 14:19:33 CONFIG: Reading configuration resource com/rapidminer/resources/rapidminerrc. (ParameterService.loadAllRCFiles())2010-09-04 14:19:33 CONFIG: Neither system property 'rapidminer.config.dir' norenvironment variable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService.getGlobalConfigDir())2010-09-04 14:19:33 CONFIG: Trying rcfile 'C:\Users\wessel\.RapidMiner5\5_0_10_rapidminerrc'...skipped (ParameterService.loadRCFile())2010-09-04 14:19:33 CONFIG: Read rcfile 'C:\Users\wessel\.RapidMiner5\5_0_10_rapidminerrc.Windows 7'. (ParameterService.loadRCFile())2010-09-04 14:19:33 CONFIG: Trying rcfile 'C:\Program Files\Rapid-I\RapidMiner5\scripts\rapidminerrc'...skipped (ParameterService.loadRCFile())2010-09-04 14:19:33 CONFIG: Trying rcfile 'C:\Program Files\Rapid-I\RapidMiner5\scripts\rapidminerrc.Windows 7'...skipped (ParameterService.loadRCFile())2010-09-04 14:19:33 CONFIG: Property rapidminer.rcfile not specified...skipped (ParameterService.loadAllRCFiles())2010-09-04 14:19:33 CONFIG: Registering Plugins (RapidMiner.splashMessage())2010-09-04 14:19:33 CONFIG: Read extension state. (ManagedExtension.readConfiguration())2010-09-04 14:19:33 CONFIG: Scanning plugins in C:\Program Files\Rapid-I\RapidMiner5\scripts\..\lib\plugins. (Plugin.findAndRegisterPlugins())2010-09-04 14:19:33 CONFIG: Loading renderers from 'Text Processing'. (RendererService.init())2010-09-04 14:19:33 CONFIG: Reading parse rules from jar:file:C:\Users\wessel\.RapidMiner5\managed\rmx_text-5.0.6.jar!/com/rapidminer/resources/parserulesTextProcessing.xml (XMLImporter.importParseRules())2010-09-04 14:19:34 CONFIG: Loading renderers from 'PMML'. (RendererService.init())2010-09-04 14:19:34 CONFIG: Reading parse rules from jar:file:C:\Users\wessel\.RapidMiner5\managed\rmx_pmml-5.0.1.jar!/com/rapidminer/resources/parserulesPMML.xml (XMLImporter.importParseRules())2010-09-04 14:19:34 CONFIG: Loading renderers from 'Weka'. (RendererService.init())2010-09-04 14:19:34 CONFIG: Reading parse rules from jar:file:C:\Users\wessel\.RapidMiner5\managed\rmx_weka-5.0.1.jar!/com/rapidminer/resources/parserulesWekaExtension.xml (XMLImporter.importParseRules())2010-09-04 14:19:34 CONFIG: Loading renderers from 'Series'. (RendererService.init())2010-09-04 14:19:34 CONFIG: Reading parse rules from jar:file:C:\Users\wessel\.RapidMiner5\managed\rmx_series-5.0.2.jar!/com/rapidminer/resources/parserulesValueSeries.xml (XMLImporter.importParseRules())2010-09-04 14:19:34 CONFIG: Initializing Operators (RapidMiner.splashMessage())2010-09-04 14:19:34 CONFIG: Loading operators from 'OperatorsCore.xml'. (OperatorService.registerOperators())2010-09-04 14:19:34 CONFIG: Loading operator documentation from jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/i18n/OperatorsCoreDocumentation.xml. (OperatorDocBundle$XMLControl.newBundle())2010-09-04 14:19:38 WARNING: Password in XML file looks like unencrypted plain text. (ParameterTypePassword.decryptPassword())2010-09-04 14:19:41 CONFIG: Loading operators from 'C:\Users\wessel\.RapidMiner5\managed\rmx_parallel-5.0.1.jar'. (OperatorService.registerOperators())2010-09-04 14:19:41 CONFIG: Loading operator documentation from jar:file:C:\Users\wessel\.RapidMiner5\managed\rmx_parallel-5.0.1.jar!/com/rapidminer/resources/i18n/OperatorsDocParallel.xml. (OperatorDocBundle$XMLControl.newBundle())2010-09-04 14:19:41 CONFIG: Loading operators from 'C:\Users\wessel\.RapidMiner5\managed\rmx_text-5.0.6.jar'. (OperatorService.registerOperators())2010-09-04 14:19:41 CONFIG: Loading operator documentation from jar:file:C:\Users\wessel\.RapidMiner5\managed\rmx_text-5.0.6.jar!/com/rapidminer/resources/i18n/OperatorsDocTextProcessing.xml. (OperatorDocBundle$XMLControl.newBundle())2010-09-04 14:19:41 CONFIG: Loading operators from 'C:\Users\wessel\.RapidMiner5\managed\rmx_pmml-5.0.1.jar'. (OperatorService.registerOperators())2010-09-04 14:19:41 CONFIG: Loading operator documentation from jar:file:C:\Users\wessel\.RapidMiner5\managed\rmx_pmml-5.0.1.jar!/com/rapidminer/resources/i18n/OperatorsDocPMML.xml. (OperatorDocBundle$XMLControl.newBundle())2010-09-04 14:19:41 CONFIG: Loading operators from 'C:\Users\wessel\.RapidMiner5\managed\rmx_weka-5.0.1.jar'. (OperatorService.registerOperators())2010-09-04 14:19:41 CONFIG: Loading operator documentation from jar:file:C:\Users\wessel\.RapidMiner5\managed\rmx_weka-5.0.1.jar!/com/rapidminer/resources/i18n/OperatorsDocWekaExtension.xml. (OperatorDocBundle$XMLControl.newBundle())2010-09-04 14:19:41 CONFIG: Creating operators from factory com.rapidminer.tools.WekaOperatorFactory (OperatorService.parseOperators())2010-09-04 14:19:46 INFO: No operator descriptor specified for plugin Community. Trying plugin initializtation class com.rapidminer.community.CommunityPluginInit. (Plugin.registerOperators())2010-09-04 14:19:46 WARNING: No operator descriptor defined for: Community (Plugin.registerOperators())2010-09-04 14:19:46 CONFIG: Loading operators from 'C:\Users\wessel\.RapidMiner5\managed\rmx_series-5.0.2.jar'. (OperatorService.registerOperators())2010-09-04 14:19:46 CONFIG: Loading operator documentation from jar:file:C:\Users\wessel\.RapidMiner5\managed\rmx_series-5.0.2.jar!/com/rapidminer/resources/i18n/OperatorsDocValueSeries.xml. (OperatorDocBundle$XMLControl.newBundle())2010-09-04 14:19:47 CONFIG: Number of registered operator classes: 556; number of registered operator descriptions: 684; number of replacements: 523 (OperatorService.init())2010-09-04 14:19:47 CONFIG: Loading operator usage statistics. (UsageStatistics.load())2010-09-04 14:19:47 CONFIG: Initializing XML Transformation Rules (RapidMiner.splashMessage())2010-09-04 14:19:47 CONFIG: Reading parse rules from jar:file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/parserules.xml (XMLImporter.importParseRules())2010-09-04 14:19:47 CONFIG: Loading JDBC Drivers (RapidMiner.splashMessage())2010-09-04 14:19:47 CONFIG: Loading JDBC driver information from 'resource jdbc_properties.xml'. (DatabaseService.loadJDBCProperties())2010-09-04 14:19:47 CONFIG: Loaded JDBC driver com.mysql.jdbc.Driver (JDBCProperties.registerDrivers())2010-09-04 14:19:47 CONFIG: Loaded JDBC driver org.postgresql.Driver (JDBCProperties.registerDrivers())2010-09-04 14:19:47 CONFIG: Loaded JDBC driver net.sourceforge.jtds.jdbc.Driver(JDBCProperties.registerDrivers())2010-09-04 14:19:47 CONFIG: Loaded JDBC driver org.hsqldb.jdbcDriver (JDBCProperties.registerDrivers())2010-09-04 14:19:47 WARNING: Missing database driver class name for 'ODBC Bridge (e.g. Access)' (JDBCProperties.<init>())2010-09-04 14:19:47 CONFIG: Loaded JDBC driver net.sourceforge.jtds.jdbc.Driver(JDBCProperties.registerDrivers())2010-09-04 14:19:47 CONFIG: Loaded JDBC driver com.ingres.jdbc.IngresDriver (JDBCProperties.registerDrivers())2010-09-04 14:19:47 CONFIG: Loaded JDBC driver ca.ingres.jdbc.IngresDriver (JDBCProperties.registerDrivers())2010-09-04 14:19:47 INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())2010-09-04 14:19:47 CONFIG: Neither system property 'rapidminer.config.dir' norenvironment variable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService.getGlobalConfigDir())2010-09-04 14:19:47 CONFIG: Initializing Data Repository (RapidMiner.splashMessage())2010-09-04 14:19:47 CONFIG: Loading repositories from C:\Users\wessel\.RapidMiner5\repositories.xml (RepositoryManager.load())2010-09-04 14:19:47 CONFIG: Adding repository RMDEFAULTINDOCUMENTS (RepositoryManager.addRepository())2010-09-04 14:19:47 CONFIG: Initializing XML Serialization (RapidMiner.splashMessage())2010-09-04 14:19:48 CONFIG: Defining XML Serialization Alias Pairs (RapidMiner.splashMessage())2010-09-04 14:19:48 CONFIG: Initializing Renderers (RapidMiner.splashMessage())2010-09-04 14:19:48 CONFIG: Loading renderers from 'file:/C:/Program%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/ioobjects.xml'. (RendererService.init())2010-09-04 14:19:48 CONFIG: Loading renderers from 'ioobjects.xml'. (RendererService.init())2010-09-04 14:19:48 INFO: No filename given for result file, using stdout for logging results! (WrapperLoggingHandler.log())2010-09-04 14:19:48 INFO: Process C:\Users\wessel\Documents\RMDEFAULT\new.rmp starts (Process.run())2010-09-04 14:19:48 INFO: Process C:\Users\wessel\Documents\RMDEFAULT\new.rmp finished successfully after 0 s (Process.run())2010-09-04 14:19:48 INFO: Process finished successfully (RapidMinerCommandLine.run())C:\Program Files\Rapid-I\RapidMiner5\scripts>
