<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="431" width="748"> <operator activated="true" class="generate_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="sum"/> </operator> <operator activated="true" class="discretize_by_user_specification" compatibility="5.0.10" expanded="true" height="94" name="Discretize" width="90" x="179" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="include_special_attributes" value="true"/> <list key="classes"> <parameter key="first" value="-10.0"/> <parameter key="second" value="0.0"/> <parameter key="third" value="10.0"/> </list> </operator> <operator activated="true" class="polynomial_by_binomial_classification" compatibility="5.0.10" expanded="true" height="76" name="Polynomial by Binomial Classification" width="90" x="313" y="210"> <process expanded="true" height="682" width="783"> <operator activated="true" class="x_validation" compatibility="5.0.0" expanded="true" height="112" name="Validation" width="90" x="112" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <parameter key="leave_one_out" value="true"/> <process expanded="true" height="654" width="466"> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.0.10" expanded="true" height="76" name="SVM" width="90" x="188" y="30"> <list key="class_weights"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="654" width="466"> <operator activated="true" class="apply_model" compatibility="5.0.0" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.0" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="training set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model (2)" width="90" x="447" y="300"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.10" expanded="true" height="76" name="Performance (2)" width="90" x="514" y="30"/> <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Polynomial by Binomial Classification" to_port="training set"/> <connect from_op="Polynomial by Binomial Classification" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Polynomial by Binomial Classification" from_port="example set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Apply Model (2)" from_port="model" to_port="result 3"/> <connect from_op="Performance (2)" from_port="performance" to_port="result 1"/> <connect from_op="Performance (2)" from_port="example set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
