<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true" height="377" width="620"> <operator activated="true" class="retrieve" compatibility="5.0.10" expanded="true" height="60" name="Retrieve" width="90" x="45" y="165"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="set_macro" compatibility="5.0.10" expanded="true" height="76" name="Set Macro" width="90" x="45" y="255"> <parameter key="macro" value="max"/> <parameter key="value" value="2"/> </operator> <operator activated="true" class="loop" compatibility="5.0.10" expanded="true" height="94" name="Loop" width="90" x="179" y="255"> <parameter key="iterations" value="%{max}"/> <parameter key="limit_time" value="false"/> <parameter key="timeout" value="1"/> <parameter key="parallelize_iteration" value="false"/> <process expanded="true" height="391" width="638"> <operator activated="true" class="generate_macro" compatibility="5.0.10" expanded="true" height="76" name="Generate Macro" width="90" x="40" y="70"> <list key="function_descriptions"> <parameter key="current_iteration" value="%{a}"/> </list> <parameter key="use_standard_constants" value="true"/> </operator> <operator activated="true" class="select_subprocess" compatibility="5.0.10" expanded="true" height="76" name="Select Subprocess" width="90" x="179" y="75"> <parameter key="select_which" value="%{current_iteration}"/> <parameter key="parallelize_selection_1" value="false"/> <parameter key="parallelize_selection_2" value="false"/> <process expanded="true" height="391" width="294"> <operator activated="true" class="x_validation" compatibility="5.0.10" expanded="true" height="112" name="Validation (3)" width="90" x="55" y="32"> <parameter key="create_complete_model" value="false"/> <parameter key="average_performances_only" value="true"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_validations" value="10"/> <parameter key="sampling_type" value="stratified sampling"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="1992"/> <parameter key="parallelize_training" value="false"/> <parameter key="parallelize_testing" value="false"/> <process expanded="true" height="391" width="294"> <operator activated="true" class="neural_net" compatibility="5.0.10" expanded="true" height="76" name="Neural Net (3)" width="90" x="56" y="48"> <list key="hidden_layers"/> <parameter key="training_cycles" value="500"/> <parameter key="learning_rate" value="0.3"/> <parameter key="momentum" value="0.2"/> <parameter key="decay" value="false"/> <parameter key="shuffle" value="false"/> <parameter key="normalize" value="true"/> <parameter key="error_epsilon" value="1.0E-5"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <connect from_port="training" to_op="Neural Net (3)" to_port="training set"/> <connect from_op="Neural Net (3)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="391" width="294"> <operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model (3)" width="90" x="69" y="51"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance" compatibility="5.0.10" expanded="true" height="76" name="Performance (3)" width="90" x="168" y="165"> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model (3)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/> <connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/> <connect from_op="Performance (3)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Validation (3)" to_port="training"/> <connect from_op="Validation (3)" from_port="averagable 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> <process expanded="true" height="391" width="294"> <operator activated="true" class="x_validation" compatibility="5.0.10" expanded="true" height="112" name="Validation (4)" width="90" x="45" y="75"> <parameter key="create_complete_model" value="false"/> <parameter key="average_performances_only" value="true"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_validations" value="10"/> <parameter key="sampling_type" value="stratified sampling"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="1992"/> <parameter key="parallelize_training" value="false"/> <parameter key="parallelize_testing" value="false"/> <process expanded="true" height="391" width="294"> <operator activated="true" class="neural_net" compatibility="5.0.10" expanded="true" height="76" name="Neural Net (4)" width="90" x="102" y="30"> <list key="hidden_layers"/> <parameter key="training_cycles" value="500"/> <parameter key="learning_rate" value="0.3"/> <parameter key="momentum" value="0.2"/> <parameter key="decay" value="false"/> <parameter key="shuffle" value="false"/> <parameter key="normalize" value="true"/> <parameter key="error_epsilon" value="1.0E-5"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <connect from_port="training" to_op="Neural Net (4)" to_port="training set"/> <connect from_op="Neural Net (4)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="391" width="294"> <operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model (4)" width="90" x="45" y="30"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance" compatibility="5.0.10" expanded="true" height="76" name="Performance (4)" width="90" x="169" y="30"> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model (4)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (4)" to_port="unlabelled data"/> <connect from_op="Apply Model (4)" from_port="labelled data" to_op="Performance (4)" to_port="labelled data"/> <connect from_op="Performance (4)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Validation (4)" to_port="training"/> <connect from_op="Validation (4)" from_port="averagable 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Select Subprocess" to_port="input 1"/> <connect from_op="Select Subprocess" from_port="output 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Loop" to_port="input 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Loop" to_port="input 2"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
