dan_agape wrote:Hi,Click on the k-Means operator box in the process and set k in the Parameters window to the desired value.BTW, the convergence of the algorithm is given by the fact that the centroids do not change in two consecutive iterations. Regarding the sum of squared distances (i.e. the squared error), it provides a criterion to select the best solution among the generated possibly multiple solutions.Regards,Dan
