Hey guys,
I am trying to do a simple Fourier Transformation with Rapidminer, but I have no luck for the last 3hours. Nevermind...
Here is the problem:
I have an Excel sheet with the following columns:
x cos(x) sin(x)
0,0000 1,0000 0
0,0491 0,9988 0,049067674
0,0982 0,9952 0,09801714
1,2272 0,3369 0,941544065
1,2763 0,2903 0,956940336
1,3254 0,2430 0,970031253
1,3744 0,1951 0,98078528
1,4235 0,1467 0,98917651
1,4726 0,0980 0,995184727
1,5217 0,0491 0,998795456
1,5708 0,0000 1
2,9943 -0,9892 0,146730474
3,0434 -0,9952 0,09801714
3,0925 -0,9988 0,049067674
3,1416 -1,0000 2,34296E-15
3,1907 -0,9988 -0,049067674
6,0868 0,9808 -0,195090322
6,1359 0,9892 -0,146730474
6,1850 0,9952 -0,09801714
6,2341 0,9988 -0,049067674
6,2832 1,0000 -1,26795E-14
and there the corresponding xml file:
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process">
<process expanded="true" height="624" width="566">
<operator activated="true" class="read_excel" compatibility="5.0.10" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="excel_file" value="C:\Dokumente und Einstellungen\pete\Desktop\test.xls"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations"/>
<parameter key="0" value="attribute_0.true.4.regular"/>
<parameter key="1" value="attribute_1.true.4.regular"/>
<parameter key="2" value="attribute_2.true.4.regular"/>
</list>
<parameter key="attribute_names_already_defined" value="true"/>
<operator activated="true" class="select_attributes" compatibility="5.0.10" expanded="true" height="76" name="Select Attributes" width="90" x="112" y="165">
<parameter key="attribute" value="attribute_2"/>
<parameter key="attributes" value="attribute_2"/>
<operator activated="true" class="fourier_transformation" compatibility="5.0.10" expanded="true" height="76" name="Fourier Transformation" width="90" x="313" y="120"/>
<connect from_op="Read Excel" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Fourier Transformation" to_port="example set input"/>
<connect from_op="Fourier Transformation" from_port="example set output" to_port="result 1"/>
</process>
</process>
Should I get normally a peak at 1hz for the sinus curve? After running the process I can the in the "DataView" 64 rows, the frequency from 0 increasing to 20.210 in 64 steps, but the fft(attribute2) still has the "?" symbol...
What is wrong wiht my process?
pete
