<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="269" width="413"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="10"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.0.8" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30"> <list key="function_descriptions"> <parameter key="att1_int" value="floor(att1)"/> <parameter key="att2_int" value="floor(att2)"/> </list> </operator> <operator activated="true" class="add_noise" compatibility="5.0.8" expanded="true" height="94" name="Add Noise" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="att1_int|att2_int"/> <parameter key="default_attribute_noise" value="1.0"/> <list key="noise"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Add Noise" to_port="example set input"/> <connect from_op="Add Noise" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="415" width="681"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="10"/> </operator> <operator activated="true" class="sample" compatibility="5.0.8" expanded="true" height="76" name="Sample" width="90" x="179" y="165"> <parameter key="sample_size" value="5"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> </operator> <operator activated="true" class="add_noise" compatibility="5.0.8" expanded="true" height="94" name="Add Noise" width="90" x="313" y="75"> <parameter key="default_attribute_noise" value="1.0"/> <list key="noise"/> </operator> <operator activated="true" class="append" compatibility="5.0.8" expanded="true" height="94" name="Append" width="90" x="514" y="165"/> <connect from_op="Generate Data" from_port="output" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Add Noise" to_port="example set input"/> <connect from_op="Sample" from_port="original" to_op="Append" to_port="example set 2"/> <connect from_op="Add Noise" from_port="example set output" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
