<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.004"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.004" expanded="true" name="Process"> <parameter key="logverbosity" value="status"/> <process expanded="true" height="761" width="1020"> <operator activated="true" class="read_csv" compatibility="5.1.004" expanded="true" height="60" name="Read CSV" width="90" x="45" y="75"> <parameter key="csv_file" value="EURUSDtrain.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="count.true.integer.attribute"/> <parameter key="1" value="open.true.real.attribute"/> <parameter key="2" value="high.true.real.attribute"/> <parameter key="3" value="low.true.real.attribute"/> <parameter key="4" value="close.true.real.attribute"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.1.004" expanded="true" height="76" name="Set Role (2)" width="90" x="179" y="75"> <parameter key="name" value="count"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.1.001" expanded="true" height="76" name="Windowing" width="90" x="313" y="75"> <parameter key="horizon" value="1"/> <parameter key="window_size" value="1"/> <parameter key="create_label" value="true"/> <parameter key="label_attribute" value="close"/> </operator> <operator activated="true" class="series:sliding_window_validation" compatibility="5.1.001" expanded="true" height="130" name="Validation" width="90" x="447" y="75"> <parameter key="training_window_step_size" value="1"/> <parameter key="test_window_width" value="5"/> <process expanded="true" height="526" width="478"> <operator activated="true" class="support_vector_machine" compatibility="5.1.004" expanded="true" height="112" name="SVM" width="90" x="249" y="133"/> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="526" width="478"> <operator activated="true" class="apply_model" compatibility="5.1.004" expanded="true" height="76" name="Apply Model" width="90" x="45" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="series:forecasting_performance" compatibility="5.1.001" expanded="true" height="76" name="Performance" width="90" x="246" y="120"> <parameter key="horizon" value="1"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> <portSpacing port="sink_averagable 3" spacing="0"/> </process> </operator> <operator activated="true" class="read_csv" compatibility="5.1.004" expanded="true" height="60" name="Read CSV (2)" width="90" x="45" y="210"> <parameter key="csv_file" value="EURUSDtest.csv"/> <parameter key="column_separators" value=","/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="count.true.integer.attribute"/> <parameter key="1" value="open.true.real.attribute"/> <parameter key="2" value="high.true.real.attribute"/> <parameter key="3" value="low.true.real.attribute"/> <parameter key="4" value="close.true.real.attribute"/> </list> </operator> <operator activated="true" class="set_role" compatibility="5.1.004" expanded="true" height="76" name="Set Role (3)" width="90" x="179" y="210"> <parameter key="name" value="count"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.1.001" expanded="true" height="76" name="Windowing (2)" width="90" x="313" y="210"> <parameter key="window_size" value="1"/> <parameter key="label_attribute" value="close"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.004" expanded="true" height="76" name="Apply Model (2)" width="90" x="581" y="300"> <list key="application_parameters"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Windowing" to_port="example set input"/> <connect from_op="Windowing" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Validation" from_port="training" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 2"/> <connect from_op="Validation" from_port="averagable 2" to_port="result 3"/> <connect from_op="Read CSV (2)" from_port="output" to_op="Set Role (3)" to_port="example set input"/> <connect from_op="Set Role (3)" from_port="example set output" to_op="Windowing (2)" to_port="example set input"/> <connect from_op="Windowing (2)" from_port="example set output" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 4"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> </process> </operator></process>
