"Generate Attribute - Deviation"
MuehliMan
New Altair Community Member
I would like to include an Operator that calculates the deviation for each example. I thought this is an easy job, but I am struggeling to include the predition(activity) attribute into the right Syntax.Here is what I tried:
Cheers,
Markus
Thanks for your help!
<operator activated="true" class="generate_attributes" compatibility="5.0.8" expanded="true" height="76" name="Generate Deviation" width="90" x="447" y="30">
<parameter key="deviatio" value="%{activity}-%{prediction(activity)}"/>
</list>
Cheers,
Markus
Hi Markus,
if 'activity' and 'prediction(activity)' are attributes, you may not write them with macro-syntax. %{macro-name} resolves the value for the macro 'macro-name' and inserts it in this place. If you want to use attributes inside the "Generate Attributes" operator simply use their names (case-sensitive) without special syntax. If you want to use text/string content you have to quote it here.
If you want to do some calculation with different attributes they need to have same types, maybe some conversion is required before this step.
Hope this helps!?
Greetings,
Matthias0 -
So as prediction and label are different types, I need to perform a type conversion beforehands? In my case all values are numerical.0
Roles may be different, as long as value types are the same this should work.
I just tested a similar (constructed) example, it seems the parentheses cause problems when trying the calculation. If you rename the attribute before (prediction_activity for example) this should work!0 -
this solved the problem, thank you!0
