So in a nutshell Read CSV cannot work if the type is not correctly interpreted for real values.
haddock wrote:So is that a true statement?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="475" width="299"> <operator activated="true" class="read_csv" compatibility="5.0.8" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="file_name" value="C:\Users\gagi\Desktop\Test.txt"/> <parameter key="use_first_row_as_attribute_names" value="false"/> </operator> <operator activated="true" class="store" compatibility="5.0.8" expanded="true" height="60" name="Store" width="90" x="179" y="30"> <parameter key="repository_entry" value="//Repository/test"/> </operator> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="179" y="120"> <parameter key="repository_entry" value="//Repository/test"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_port="result 1"/> <connect from_op="Retrieve" from_port="output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="72"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
if (!Tools.isEqual(Math.round(number.doubleValue()), number.intValue())) { canParseInteger = false;}
values = number;
Marco Boeck wrote:Hello gulyasg,I'm afraid your RapidMiner version is quite old. That bug has been fixed for quite some time You may want to consider updating to the latest version, which is 5.1.002.Regards,Marco
