<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.0" expanded="true" name=""> <process expanded="true" height="365" width="748"> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="179" y="75"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="loop_attribute_subsets" compatibility="5.0.8" expanded="true" height="60" name="Loop Subsets" width="90" x="380" y="75"> <parameter key="use_exact_number" value="true"/> <parameter key="exact_number_of_attributes" value="2"/> <process expanded="true" height="380" width="815"> <operator activated="true" class="x_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation" width="90" x="246" y="75"> <process expanded="true" height="380" width="438"> <operator activated="true" class="decision_tree" compatibility="5.0.8" expanded="true" height="76" name="Decision Tree" width="90" x="95" y="144"/> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="380" width="438"> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model" width="90" x="25" y="47"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.0.8" expanded="true" height="76" name="Performance" width="90" x="231" y="38"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.0.8" expanded="true" height="76" name="Log" width="90" x="581" y="30"> <list key="log"> <parameter key="Attributes" value="operator.Loop Subsets.value.feature_names"/> <parameter key="Performance" value="operator.Validation.value.performance"/> </list> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <portSpacing port="source_example set" spacing="0"/> </process> </operator> <operator activated="true" class="log_to_data" compatibility="5.0.8" expanded="true" height="94" name="Log to Data" width="90" x="571" y="73"/> <connect from_op="Retrieve" from_port="output" to_op="Loop Subsets" to_port="example set"/> <connect from_op="Loop Subsets" from_port="example set" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_port="result 1"/> <connect from_op="Log to Data" from_port="through 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <parameter key="logverbosity" value="3"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="1"/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true" height="550" width="480"> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="165"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="read_model" compatibility="5.0.8" expanded="true" height="60" name="Read Model" width="90" x="45" y="75"> <parameter key="model_file" value="C:\Users\dan\Desktop\model_DT.mod"/> </operator> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model" width="90" x="179" y="75"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.0.8" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="75"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="0"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="11"/> <parameter key="block_type" value="0"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="8"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <connect from_op="Retrieve (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Read Model" from_port="output" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Apply Model" from_port="model" to_port="result 2"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="36"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
How can one alternatively drop the confidence attributes, as it seems that these and the prediction attribute are not visible by the select attribute operator, which is practically not useful here?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="550" width="547"> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="165"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="k_nn" compatibility="5.0.8" expanded="true" height="76" name="k-NN" width="90" x="173" y="155"/> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model" width="90" x="313" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.0.8" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="210"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="pred.*"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_op="Retrieve (2)" from_port="output" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="k-NN" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Apply Model" from_port="model" to_port="result 2"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="36"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
