Hello all,
I have the following process
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process">
<process expanded="true" height="682" width="759">
<operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="discretize_by_bins" compatibility="5.0.8" expanded="true" height="94" name="Discretize" width="90" x="179" y="30">
<parameter key="attribute" value="label"/>
<parameter key="attributes" value="label"/>
<operator activated="true" class="nominal_to_binominal" compatibility="5.0.8" expanded="true" height="94" name="Nominal to Binominal" width="90" x="313" y="30">
<operator activated="true" class="x_validation" compatibility="5.0.0" expanded="true" height="112" name="Validation" width="90" x="447" y="30">
<description>A cross-validation evaluating a decision tree model.</description>
<process expanded="true" height="654" width="466">
<operator activated="true" class="logistic_regression" compatibility="5.0.8" expanded="true" height="94" name="Logistic Regression" width="90" x="188" y="30"/>
<connect from_port="training" to_op="Logistic Regression" to_port="training set"/>
<connect from_op="Logistic Regression" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.0.0" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance" compatibility="5.0.0" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/>
<connect from_op="Discretize" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/>
<connect from_op="Nominal to Binominal" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
<connect from_op="Validation" from_port="training" to_port="result 2"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 3"/>
</process>
</process>
It has the error "Input example set must have special attribute 'label'."
I can easily get rid of this by changing the parameter "range name type" from long to short. I suppose this is a bug and I often encounter little issues like this that I have to workaround. I don't mind too much given the open source status of the product.
I run the process in the two cases with and without the error and I get the same performance vector so on the face of it, the error has no effect. My question is however, is this always true? What validation errors can I safely ignore to save myself workaround time?
regards
Andrew
