<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.0" expanded="true" name=""> <process expanded="true" height="365" width="547"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="180" y="30"/> <operator activated="true" class="loop_attributes" compatibility="5.0.8" expanded="true" height="60" name="Loop Attributes" width="90" x="447" y="75"> <parameter key="iteration_macro" value="loop_attribute1"/> <process expanded="true" height="383" width="413"> <operator activated="true" class="work_on_subset" compatibility="5.0.8" expanded="true" height="76" name="Work on Subset" width="90" x="112" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="%{loop_attribute1}"/> <parameter key="invert_selection" value="true"/> <process expanded="true" height="383" width="926"> <operator activated="true" class="loop_attributes" compatibility="5.0.8" expanded="true" height="60" name="Loop Attributes (2)" width="90" x="246" y="28"> <parameter key="iteration_macro" value="loop_attribute2"/> <process expanded="true" height="383" width="926"> <operator activated="true" class="set_macro" compatibility="5.0.8" expanded="true" height="76" name="Set Macro" width="90" x="161" y="20"> <parameter key="macro" value="combined"/> <parameter key="value" value="%{loop_attribute1}/%{loop_attribute2}"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.0.8" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="355" y="19"> <parameter key="macro_name" value="combined"/> </operator> <operator activated="true" class="log" compatibility="5.0.8" expanded="true" height="76" name="Log" width="90" x="537" y="17"> <list key="log"> <parameter key="atts" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> </operator> <connect from_port="example set" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_port="exampleSet" to_op="Loop Attributes (2)" to_port="example set"/> <connect from_op="Loop Attributes (2)" from_port="example set" to_port="example set"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Work on Subset" to_port="example set"/> <connect from_op="Work on Subset" from_port="example set" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="383" width="908"> <operator activated="true" class="generate_data" compatibility="5.0.8" expanded="true" height="60" name="Generate Data" width="90" x="77" y="86"/> <operator activated="true" class="generate_function_set" compatibility="5.0.8" expanded="true" height="76" name="Generate Function Set" width="90" x="332" y="83"> <parameter key="use_diff" value="true"/> </operator> <operator activated="true" class="rename_by_constructions" compatibility="5.0.8" expanded="true" height="76" name="Rename by Constructions" width="90" x="486" y="81"/> <connect from_op="Generate Data" from_port="output" to_op="Generate Function Set" to_port="example set input"/> <connect from_op="Generate Function Set" from_port="example set output" to_op="Rename by Constructions" to_port="example set input"/> <connect from_op="Rename by Constructions" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
