<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="521" width="614"> <operator activated="true" class="series:generate_example_set_series" compatibility="5.0.2" expanded="true" height="60" name="Generate Data (Series)" width="90" x="45" y="75"> <parameter key="number_of_examples" value="200"/> <parameter key="number_of_frequencies" value="1"/> </operator> <operator activated="true" class="series:process_series" compatibility="5.0.2" expanded="true" height="76" name="Process Series" width="90" x="179" y="75"> <parameter key="start_attribute" value="att0"/> <parameter key="end_attribute" value="att512"/> <process expanded="true" height="716" width="707"> <operator activated="true" class="series:window_transformation" compatibility="5.0.2" expanded="true" height="60" name="Window Transformation" width="90" x="45" y="75"> <parameter key="function_type" value="Bartlett"/> </operator> <operator activated="true" class="series:discrete_fourier_transformation" compatibility="5.0.2" expanded="true" height="60" name="Discrete Fourier Transformation" width="90" x="179" y="75"/> <operator activated="true" class="series:extract_peak" compatibility="5.0.2" expanded="true" height="60" name="Extract Peak" width="90" x="313" y="75"> <parameter key="number_of_peaks" value="1"/> </operator> <connect from_port="series" to_op="Window Transformation" to_port="series"/> <connect from_op="Window Transformation" from_port="series" to_op="Discrete Fourier Transformation" to_port="series"/> <connect from_op="Discrete Fourier Transformation" from_port="series" to_op="Extract Peak" to_port="series"/> <connect from_op="Extract Peak" from_port="series" to_port="series"/> <portSpacing port="source_series" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_series" spacing="0"/> </process> </operator> <operator activated="true" class="x_validation" compatibility="5.0.0" expanded="true" height="112" name="Validation" width="90" x="380" y="75"> <description>A cross validation including a linear regression.</description> <process expanded="true" height="654" width="466"> <operator activated="true" class="support_vector_machine" compatibility="5.0.8" expanded="true" height="112" name="SVM" width="90" x="188" y="30"/> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="654" width="466"> <operator activated="true" class="apply_model" compatibility="5.0.0" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.0" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data (Series)" from_port="output" to_op="Process Series" to_port="example set"/> <connect from_op="Process Series" from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
