Altair RISE
Nominate Yourself Now!
Altair RapidMiner
"SOM Visualization problem -"
karlrb
Problem:
I can't actually see the SOM. I just get the message below the ModelVisualization line. Perhaps it's
just a setup issue? Forgive me if I've sent too much data.
Thank you,
Karl Bergerson
Operators
Evaluation
visual Evaluation
% Visualize Model by SOM
ModelVisualization
com.rapidminer.operator.visualization.SOMModelVisualization$SOMModelVisualizationResult@72ef1c4d
gt2c.rmp
<process version="5.0">
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
<location/>
<location/>
</output>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<parameter key="logverbosity" value="3"/>
<parameter key="send_mail" value="1"/>
<parameter key="parallelize_main_process" value="false"/>
<process expanded="true" height="628" width="875">
<operator activated="true" class="read_aml" expanded="true" height="60" name="Read AML" width="90" x="45" y="30">
<parameter key="attributes" value="C:\Rapidminer\spy_bs10.aml"/>
<parameter key="sample_ratio" value="1.0"/>
<parameter key="sample_size" value="-1"/>
<parameter key="permute" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="column_separators" value=",\s*|;\s*|\s+"/>
<parameter key="use_comment_characters" value="true"/>
<parameter key="comment_chars" value="#"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quote_character" value="""/>
<parameter key="quoting_escape_character" value="\"/>
<parameter key="trim_lines" value="false"/>
<parameter key="skip_error_lines" value="false"/>
<parameter key="datamanagement" value="0"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="179" y="30">
<parameter key="create_complete_model" value="false"/>
<parameter key="average_performances_only" value="true"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_validations" value="10"/>
<parameter key="sampling_type" value="2"/>
<parameter key="parallelize_training" value="false"/>
<parameter key="parallelize_testing" value="false"/>
<process expanded="true" height="628" width="412">
<operator activated="true" class="tree_to_rules" expanded="true" height="76" name="Tree to Rules" width="90" x="45" y="30">
<parameter key="parallelize_learning_process" value="false"/>
<process expanded="true">
<operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30">
<parameter key="criterion" value="gini_index"/>
<parameter key="minimal_size_for_split" value="4"/>
<parameter key="minimal_leaf_size" value="2"/>
<parameter key="minimal_gain" value="0.1"/>
<parameter key="maximal_depth" value="20"/>
<parameter key="confidence" value="0.25"/>
<parameter key="number_of_prepruning_alternatives" value="3"/>
<parameter key="no_pre_pruning" value="false"/>
<parameter key="no_pruning" value="false"/>
<connect from_port="training set" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<connect from_port="training" to_op="Tree to Rules" to_port="training set"/>
<connect from_op="Tree to Rules" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<parameter key="create_view" value="false"/>
<operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="180" y="30">
<parameter key="use_example_weights" value="true"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="visualize_model_by_som" expanded="true" height="94" name="Visualize Model by SOM" width="90" x="313" y="30"/>
<connect from_op="Read AML" from_port="output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_op="Visualize Model by SOM" to_port="model"/>
<connect from_op="Validation" from_port="training" to_op="Visualize Model by SOM" to_port="example set"/>
<connect from_op="Visualize Model by SOM" from_port="example set" to_port="result 1"/>
<connect from_op="Visualize Model by SOM" from_port="model" to_port="result 2"/>
<connect from_op="Visualize Model by SOM" from_port="visualization" to_port="result 3"/>
</process>
</process>
Visualization + Dashboards
Comments
There are no comments yet
My Discussions
