E, contact stiffness change - modal analysis
jakub.ziontek
jakub.ziontek Altair Community Member
Hi, I have model (from ansys classic), I imported it to hm, and change solver to Optistruct, all elements types changed so ok.
I have test results (two Hz values one for horizontal and one vertical mode shape), I would like to modify Young modulus, and contact stiffness.
Is it possible to run such optimization in Optistruct? What responses, and objective I need to set. I short... how make it work? :-)
Best regards,
Jakub.
  • Altair Forum User
    Altair Forum User
    edited December 2016
    Hi Jakub,
    Instead you can convert the solver deck from Ansys to OptiStruct. Use Tools>>Convert>> Ansys>> To OptiStruct
    What optimization are you looking at?
    Using Size optimization one can define material properties as design variables.
  • jakub.ziontek
    I have lots of mode shapes, but i want two of them to change frequency (to what I desired) by changing Young modulus of parts, and contact stiffness's, there is lots of parts and contact (full engine).
    Jakub
  • jakub.ziontek
    unfortunately there are errors when i want to check if modal analisys calculates after convertion to optistruct, I was hoping it will be fast :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
  • Altair Forum User
    Altair Forum User
    Jakub,
    Can you let me know what errors you have while solving?
