<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="607" width="787"> <operator activated="true" class="web:get_webpage" compatibility="5.0.3" expanded="true" height="60" name="Get Page" width="90" x="45" y="30"> <parameter key="url" value="http://www.microsoft.com/en/us/default.aspx"/> <parameter key="random_user_agent" value="true"/> <list key="query_parameters"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.0.6" expanded="true" height="94" name="Process Documents" width="90" x="179" y="30"> <process expanded="true" height="607" width="787"> <operator activated="true" class="text:tokenize" compatibility="5.0.6" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:wordlist_to_data" compatibility="5.0.6" expanded="true" height="76" name="WordList to Data" width="90" x="313" y="75"/> <operator activated="true" class="write_csv" compatibility="5.0.8" expanded="true" height="60" name="Write CSV" width="90" x="447" y="75"> <parameter key="csv_file" value="C:\test.csv"/> </operator> <connect from_op="Get Page" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <connect from_op="Process Documents" from_port="word list" to_op="WordList to Data" to_port="word list"/> <connect from_op="WordList to Data" from_port="example set" to_op="Write CSV" to_port="input"/> <connect from_op="Write CSV" from_port="through" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
