Ingo Mierswa wrote:Hi,in principle there is not so much of a difference if you tune the Weka parameters or those of RapidMiner operators. Did you already try the parameter optimization operators which could try to automatically find optimal parameter combinations?Cheers,Ingo
Ghostrider wrote:I have a lot of data which is labeled into 4-5 classification groups. I have 3-4 positive groups and 1 negative group. I'm really interested in classifying the 3-4 positive groups, but the negative group makes up > 99% of the data. So if I try to optimize for accuracy, I end up with a tree with 1000 nodes, basically just curve fitting the data. If I set a minimum number of instances per node very high, in the extreme case, it just assigns everything to the positive group. Does anyone have some suggestions for dealing with this issue? Anyone know of a good guide for WEKA parameter tuning?
hi,I have a question concerning undersampling:
how is it best done, I mean it could be the case that you choose the undersampled part of the negative class, that is very similar to just the 0.01% positive class.. or it could be that just that undersampled negative class is very different to the positive minority class... which gives extremely different decision trees at the end I guess..?
what is recommended for that case then? Split the majority negative class into several portions with sizes equal to the positive class...and use them each for one round to built the decision tree? and then average / majority vote all trees at the end?
