While I was using version 4 of Rapid Miner I built a chain to perform this function. It is discussed here:
http://rapid-i.com/rapidforum/index.php/topic,1201.msg4577.html#msg4577 and here:
http://rapid-i.com/rapidforum/index.php/topic,680.msg2587.html#msg2587.
With the advent of Rapid Miner 5 I was wondering if there are some new/better operators to allow this function.
The basic requirement is to compare a single (test) document to a set of documents and find the document in the set that best matches the test document (cosine similarity).
Any recommendations?
Thank you.
Charles
