<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.0" expanded="true" name="Process"> <process expanded="true" height="455" width="701"> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="26" y="34"> <parameter key="repository_entry" value="Prob#05_all"/> </operator> <operator activated="true" class="x_validation" compatibility="5.0.8" expanded="true" height="112" name="Validation" width="90" x="246" y="30"> <parameter key="average_performances_only" value="false"/> <parameter key="leave_one_out" value="true"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="100"/> <process expanded="true" height="473" width="354"> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.0.8" expanded="true" height="76" name="SVM" width="90" x="112" y="30"> <parameter key="gamma" value="1.2207E-4"/> <parameter key="C" value="0.5"/> <parameter key="cache_size" value="250"/> <list key="class_weights"/> <parameter key="calculate_confidences" value="true"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="473" width="354"> <operator activated="true" class="apply_model" compatibility="5.0.8" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.0.8" expanded="true" height="76" name="Performance" width="90" x="179" y="30"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
