Hi Everybody
I have a mac mini with OS X 10.4, all updates installed
Since Apple did not release java 1.6 for this version of the OS, I've installed soy latte (
http://landonf.bikemonkey.org/static/soylatte/), an Open Source implementaion of the JDK for 1.6
If I execute java -version command I get
./soylatte16-i386-1.0.2/bin/java -version
java version "1.6.0_03-p3"
Java(TM) SE Runtime Environment (build 1.6.0_03-p3-landonf_03_feb_2008_02_12-b00)
Java HotSpot(TM) Server VM (build 1.6.0_03-p3-landonf_03_feb_2008_02_12-b00, mixed mode)This jvm works great, swing works, everything java works, but when I start rapid miner I get
Launching RapidMiner, platform ANY Exception in thread "main" java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.rapid_i.Launcher.main(Launcher.java:334)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class sun.awt.X11GraphicsEnvironment at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:68)
at sun.awt.X11.XToolkit.<clinit>(XToolkit.java:89)
at java.awt.Toolkit$2.run(Toolkit.java:836)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:828)
at sun.swing.SwingUtilities2$AATextInfo.getAATextInfo(SwingUtilities2.java:120)
at javax.swing.plaf.metal.MetalLookAndFeel.initComponentDefaults(MetalLookAndFeel.java:1556)
at javax.swing.plaf.basic.BasicLookAndFeel.getDefaults(BasicLookAndFeel.java:130)
at javax.swing.plaf.metal.MetalLookAndFeel.getDefaults(MetalLookAndFeel.java:1591)
at javax.swing.UIManager.setLookAndFeel(UIManager.java:537)
at javax.swing.UIManager.setLookAndFeel(UIManager.java:577)
at javax.swing.UIManager.initializeDefaultLAF(UIManager.java:1331)
at javax.swing.UIManager.initialize(UIManager.java:1418)
at javax.swing.UIManager.maybeInitialize(UIManager.java:1406)
at javax.swing.UIManager.getDefaults(UIManager.java:656)
at javax.swing.UIManager.getColor(UIManager.java:698)
at com.vlsolutions.swing.docking.ui.DockingUISettings.<init>(DockingUISettings.java:156)
at com.rapidminer.gui.look.ui.RapidDockingUISettings.<init>(RapidDockingUISettings.java:34)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:198)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:524)
... 5 more
I do have X11 installed, so why do I get this error?
Is it related to plaf? How do I disable the Aqua plaf? Is it possible to disable the skins of the UI and use plain old java swing?
Any help would be appreciated
