"Generate attribute if clause"
Hello again,
I have troubles getting an operator to work:
Thanks in advance,
Markus
I want to add the values from the attributes "PT_old" and "PT_add" to the new column PT.
<operator activated="true" class="generate_attributes" compatibility="5.0.0" expanded="true" height="76" name="Generate Attributes (27)" width="90" x="179" y="435">
<parameter key="PT" value="if( PT_old=NaN , PT_add , PT_old )"/>
</list>
<parameter key="keep_all" value="true"/>
Thanks in advance,
Markus
1 - 2 of
21
Unfortunately the formula parser does not recognise NaN, so you have to fool it if you can! With numbers this seems to work.. Not quite sure what you'd do for nominals, but you get the idea..
