<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="381" width="868"> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="93" y="75"> <parameter key="column_separators" value="\||,\s*|;\s*|\s+"/> </operator> <connect from_op="Read CSV" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
