return preprocessing model in Normalize operator
dirk120
I can't find the "return preprocessing model" parameters even in expert mode. The description indictates that the operator supports this parameter. I run version 5.0.006
Does anyone have an idea?
Thanks,
Dirk
haddock
Hi Dirk, and welcome!
In short, it is not a parameter - it is boolean that you select if you want the normalisation model to be returned, You would use such a model to normalise other examplesets in a compatible way. Hope that is comprehensible
dirk120
But how can I select it? It thus not appear on configuration menu of the operator.
Thanks,
Dirk
haddock
Mmm, the last time I used this was under 4.6, and it looks as though the documentation is not in step with the code ( 5.006 does not have this as an option in the code and just delivers the model ). Actually given the 'ports' feature of 5.00N this makes sense.
I should ignore this, it can hardly be material, it would not be the first request for co-ordinated dox, but let it join the queue >:(
Ciao
dirk120
I'm not sure whether the model is returned. Export and results do not show any model data.
haddock
On my setup it is returned at the lower output port - marked 'pre' ( for pre-processing model )?
land
haddock is right (as so often): The preprocessing model is now returned if the "pre" port is connected to another operator or a process sink. You might recognize that an additional parameter is simply unnecessary: If you connect the port to use it, it is generate, otherwise you cannot use it at all...
And in near future the documentation will be maintained as a wiki: So maintaining it will become much easier. The most intriguing aspect of this solution is: I can always point you to the documentation and write: "So, now you can go ahead, go ahead and correct it yourself" :P
Greetings,
Sebastian
