I'm getting a null pointer exception in a very simple text process. Here is the log message:
Jun 11, 2010 1:02:31 PM INFO: No filename given for result file, using stdout for logging results!
Jun 11, 2010 1:02:31 PM INFO: Loading initial data.
Jun 11, 2010 1:02:31 PM INFO: Process starts
Jun 11, 2010 1:02:31 PM WARNING: Insufficient input for Process.input 1
Jun 11, 2010 1:02:32 PM INFO: Executing process concurrently: Vector Creation
Jun 11, 2010 1:02:32 PM WARNING: Caught exception in concurrent execution of Filter Tokens (by Length) (Filter Tokens (by Length)): java.lang.NullPointerException
Jun 11, 2010 1:02:32 PM WARNING: Caught exception in concurrent execution of Filter Stopwords (English) (Filter Stopwords (English)): java.lang.NullPointerException
Jun 11, 2010 1:02:32 PM WARNING: Caught exception in concurrent execution of Stem (Porter) (Stem (Porter)): java.lang.NullPointerException
Jun 11, 2010 1:02:32 PM INFO: Stem (Porter): Process stopped.
Jun 11, 2010 1:02:32 PM WARNING: Caught exception in concurrent execution of Stem (Porter) (Stem (Porter)): com.rapidminer.operator.ProcessStoppedException: Process stopped in Stem (Porter)
Jun 11, 2010 1:02:32 PM SEVERE: Process failed: operator cannot be executed. Check the log messages...
Jun 11, 2010 1:02:32 PM SEVERE: Here: Process[1] (Process)
subprocess 'Main Process'
+- Process Documents from Files[1] (Process Documents from Files)
subprocess 'Vector Creation'
+- Tokenize[6] (Tokenize)
+- Filter Stopwords (English)[8] (Filter Stopwords (English))
==> +- Filter Tokens (by Length)[8] (Filter Tokens (by Length))
+- Stem (Porter)[7] (Stem (Porter))
+- Generate n-Grams (Terms)[6] (Generate n-Grams (Terms))
Jun 11, 2010 1:02:32 PM SEVERE: java.lang.NullPointerException
Jun 11, 2010 1:02:32 PM INFO: Generate n-Grams (Terms): Process stopped.
Jun 11, 2010 1:02:32 PM WARNING: Caught exception in concurrent execution of Generate n-Grams (Terms) (Generate n-Grams (Terms)): com.rapidminer.operator.ProcessStoppedException: Process stopped in Generate n-Grams (Terms)
And here is the XML for the process flow:
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="161" width="765">
<operator activated="true" breakpoints="after" class="text:process_document_from_file" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30">
<list key="text_directories">
<parameter key="Test Input" value="C:\Documents and Settings\ccowan5\Desktop\Mining\TestPP"/>
</list>
<parameter key="parallelize_vector_creation" value="true"/>
<process expanded="true" height="365" width="783">
<operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
<operator activated="true" class="text:filter_stopwords_english" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="179" y="30"/>
<operator activated="true" class="text:filter_by_length" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="313" y="30">
<parameter key="min_chars" value="3"/>
<operator activated="true" class="text:stem_porter" expanded="true" height="60" name="Stem (Porter)" width="90" x="447" y="30"/>
<operator activated="true" class="text:generate_n_grams_terms" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="581" y="30"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
<connect from_op="Stem (Porter)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
</process>
<connect from_port="input 1" to_op="Process Documents from Files" to_port="word list"/>
<connect from_op="Process Documents from Files" from_port="example set" to_port="result 1"/>
</process>
</process>
Am I doing something wrong or is there a bug?
Thank you.
Charles
