<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="339" width="795"> <operator activated="true" class="web:read_rss" expanded="true" height="60" name="Read RSS Feed" width="90" x="67" y="41"> <parameter key="url" value="http://pipes.yahoo.com/pipes/pipe.run?_id=ac1eb8b5a37926f02d3edcb857158e4a&_render=rss"/> </operator> <operator activated="true" class="text:process_document_from_data" expanded="true" height="76" name="Process Documents from Data" width="90" x="268" y="41"> <parameter key="vector_creation" value="Term Occurrences"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true" height="357" width="813"> <operator activated="true" class="text:filter_stopwords_english" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="112" y="30"/> <operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="447" y="75"/> <connect from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="433" y="40"> <parameter key="name" value="text"/> <parameter key="target_role" value="id"/> </operator> <connect from_op="Read RSS Feed" from_port="output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
