<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Root"> <description></description> <parameter key="logverbosity" value="warning"/> <process expanded="true" height="335" width="413"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/> <operator activated="true" class="k_means" expanded="true" height="76" name="KMeans" width="90" x="313" y="165"> <parameter key="add_as_label" value="true"/> </operator> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="484" y="163"> <list key="application_parameters"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="KMeans" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="KMeans" from_port="cluster model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 2"/> <connect from_op="Apply Model" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="108"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="18"/> </process> </operator></process>
