G'Day all,
I was trying something quite strait forward and it just wont work for me.
As per the title, I have some data, to which I trained a classifier, and wish to better understand my situation by examining the records which failed to classify. To (attempt to) do this, I re-apply the trained model to the original training data and use the "filter examples" operator to select the errant classifications. The problem is that I always get 0 examples returned in the final set.
I've spent the whole day trying to discover what I am doing wrong without any progress and could really use some assistance.
Below is a typical example (adapted to use sample data) of my attempts to do this using the "filter examples" operator,
On both of my machines this fails to discover the errant classification set.
Thanks for any help or Ideas,
-dm
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="424" width="681">
<operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="75">
<parameter key="repository_entry" value="//Samples/data/Sonar"/>
<operator activated="true" class="select_by_random" expanded="true" height="76" name="Select by Random" width="90" x="45" y="165">
<parameter key="use_fixed_number_of_attributes" value="true"/>
<parameter key="number_of_attributes" value="20"/>
<operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="112" y="255"/>
<operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="246" y="75">
<process expanded="true" height="442" width="268">
<operator activated="true" class="k_nn" expanded="true" height="76" name="k-NN (2)" width="90" x="112" y="75"/>
<connect from_port="training" to_op="k-NN (2)" to_port="training set"/>
<connect from_op="k-NN (2)" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="36"/>
</process>
<process expanded="true" height="442" width="279">
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="112" y="165"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (2)" width="90" x="380" y="255">
<operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples" width="90" x="514" y="165">
<parameter key="condition_class" value="wrong_predictions"/>
<connect from_op="Retrieve (2)" from_port="output" to_op="Select by Random" to_port="example set input"/>
<connect from_op="Select by Random" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Validation" to_port="training"/>
<connect from_op="Multiply" from_port="output 2" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_port="result 2"/>
</process>
</process>
