<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="206" width="681"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="111" y="67"> <parameter key="attributes_lower_bound" value="-1.0E-100"/> <parameter key="attributes_upper_bound" value="1.0E-100"/> </operator> <operator activated="true" class="format_numbers" expanded="true" height="76" name="Format Numbers" width="90" x="313" y="75"> <parameter key="format_type" value="pattern"/> <parameter key="pattern" value="0.###E0"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Format Numbers" to_port="example set input"/> <connect from_op="Format Numbers" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
