"Optimization of SVM"
funnyhat
funnyhat New Altair Community Member
I have been wasting a while on the SVM optimization (or maybe not). The question is more or less same as http://rapid-i.com/rapidforum/index.php/topic,1573.0.html, From Rapido ,
The idea is
1. generate data (binomial label)
2. transform the data
3. Parameter optimization with xvalidation, but AUC will be the main control parameter
4. Draw the best parameter's ROC and show AUC
but when i ran the process, the output is always negtive. (the machine judge everything to negtive), This really confused me...  Thanks for advance
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
- <process version="5.0">
- <context>
  <input />
  <output />
  <macros />
  </context>
- <operator activated="true" class="process" expanded="true" name="Root">
  <description />
  <parameter key="logverbosity" value="3" />
  <parameter key="random_seed" value="2001" />
  <parameter key="send_mail" value="1" />
  <parameter key="process_duration_for_mail" value="30" />
  <parameter key="encoding" value="SYSTEM" />
- <process expanded="true" height="440" width="560">
- <operator activated="true" class="generate_data" expanded="true" height="60" name="TrainData" width="90" x="45" y="30">
  <parameter key="target_function" value="random classification" />
  <parameter key="number_examples" value="100" />
  <parameter key="number_of_attributes" value="5" />
  <parameter key="attributes_lower_bound" value="-10.0" />
  <parameter key="attributes_upper_bound" value="10.0" />
  <parameter key="use_local_random_seed" value="false" />
  <parameter key="local_random_seed" value="1992" />
  <parameter key="datamanagement" value="0" />
- <operator activated="true" class="normalize" expanded="true" height="94" name="Ztransformation" width="90" x="180" y="30">
  <parameter key="return_preprocessing_model" value="true" />
  <parameter key="create_view" value="false" />
  <parameter key="attribute_filter_type" value="0" />
  <parameter key="attribute" value="" />
  <parameter key="use_except_expression" value="false" />
  <parameter key="value_type" value="0" />
  <parameter key="use_value_type_exception" value="false" />
  <parameter key="except_value_type" value="2" />
  <parameter key="block_type" value="0" />
  <parameter key="use_block_type_exception" value="false" />
  <parameter key="except_block_type" value="2" />
  <parameter key="invert_selection" value="false" />
  <parameter key="include_special_attributes" value="false" />
  <parameter key="method" value="0" />
  <parameter key="min" value="0.0" />
  <parameter key="max" value="1.0" />
- <operator activated="true" class="remember" expanded="true" height="60" name="IOStorer" width="90" x="313" y="30">
  <parameter key="name" value="data" />
  <parameter key="io_object" value="ExampleSet" />
  <parameter key="store_which" value="1" />
  <parameter key="remove_from_process" value="false" />
- <operator activated="true" class="optimize_parameters_grid" expanded="true" height="148" name="ParameterOptimization" width="90" x="313" y="120">
- <list key="parameters">
  <parameter key="Training.gamma" value="[0.0;1024;16;quadratic]" />
  <parameter key="Training.C" value="[0.0;1000;10;quadratic]" />
  </list>
- <process expanded="true" height="410" width="542">
- <operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="112" y="30">
  <parameter key="create_complete_model" value="false" />
  <parameter key="average_performances_only" value="true" />
  <parameter key="leave_one_out" value="false" />
  <parameter key="number_of_validations" value="10" />
  <parameter key="sampling_type" value="shuffled sampling" />
- <process expanded="true" height="428" width="255">
- <operator activated="true" class="support_vector_machine_libsvm" expanded="true" height="76" name="Training" width="90" x="82" y="30">
  <parameter key="svm_type" value="0" />
  <parameter key="kernel_type" value="2" />
  <parameter key="degree" value="5" />
  <parameter key="gamma" value="1024.0" />
  <parameter key="coef0" value="0.0" />
  <parameter key="C" value="1000.0" />
  <parameter key="nu" value="0.5" />
  <parameter key="cache_size" value="80" />
  <parameter key="epsilon" value="0.01" />
  <parameter key="p" value="0.1" />
  <list key="class_weights" />
  <parameter key="shrinking" value="true" />
  <parameter key="calculate_confidences" value="false" />
  <parameter key="confidence_for_multiclass" value="true" />
  <connect from_port="training" to_op="Training" to_port="training set" />
  <connect from_op="Training" from_port="model" to_port="model" />
  <portSpacing port="source_training" spacing="0" />
  <portSpacing port="sink_model" spacing="0" />
  <portSpacing port="sink_through 1" spacing="0" />
  </process>
- <process expanded="true" height="428" width="279">
- <operator activated="true" class="apply_model" expanded="true" height="76" name="Test" width="90" x="45" y="30">
  <list key="application_parameters" />
- <operator activated="true" class="performance_binominal_classification" expanded="true" height="76" name="Performance (2)" width="90" x="112" y="210">
  <parameter key="main_criterion" value="AUC" />
  <parameter key="accuracy" value="true" />
  <parameter key="classification_error" value="false" />
  <parameter key="kappa" value="false" />
  <parameter key="AUC (optimistic)" value="false" />
  <parameter key="AUC" value="true" />
  <parameter key="AUC (pessimistic)" value="false" />
  <parameter key="precision" value="false" />
  <parameter key="recall" value="false" />
  <parameter key="lift" value="false" />
  <parameter key="fallout" value="false" />
  <parameter key="f_measure" value="false" />
  <parameter key="false_positive" value="false" />
  <parameter key="false_negative" value="false" />
  <parameter key="true_positive" value="false" />
  <parameter key="true_negative" value="false" />
  <parameter key="sensitivity" value="false" />
  <parameter key="specificity" value="false" />
  <parameter key="youden" value="false" />
  <parameter key="positive_predictive_value" value="false" />
  <parameter key="negative_predictive_value" value="false" />
  <parameter key="psep" value="false" />
  <parameter key="skip_undefined_labels" value="true" />
  <parameter key="use_example_weights" value="true" />
  <connect from_port="model" to_op="Test" to_port="model" />
  <connect from_port="test set" to_op="Test" to_port="unlabelled data" />
  <connect from_op="Test" from_port="labelled data" to_op="Performance (2)" to_port="labelled data" />
  <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1" />
  <portSpacing port="source_model" spacing="0" />
  <portSpacing port="source_test set" spacing="0" />
  <portSpacing port="source_through 1" spacing="0" />
  <portSpacing port="sink_averagable 1" spacing="0" />
  <portSpacing port="sink_averagable 2" spacing="0" />
  </process>
- <operator activated="true" class="log" expanded="true" height="112" name="Log" width="90" x="313" y="120">
  <parameter key="filename" value="paraopt.log" />
- <list key="log">
  <parameter key="C" value="operator.Training.parameter.C" />
  <parameter key="Gamma" value="operator.Training.parameter.gamma" />
  <parameter key="absolute" value="operator.BinominalClassificationPerformance.value.performance" />
  <parameter key="auc" value="operator.Final Performance.value.AUC" />
  </list>
  <parameter key="sorting_type" value="0" />
  <parameter key="sorting_k" value="100" />
  <parameter key="persistent" value="false" />
  <connect from_port="input 1" to_op="Validation" to_port="training" />
  <connect from_port="input 2" to_op="Log" to_port="through 3" />
  <connect from_op="Validation" from_port="training" to_op="Log" to_port="through 1" />
  <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 2" />
  <connect from_op="Log" from_port="through 1" to_port="result 1" />
  <connect from_op="Log" from_port="through 2" to_port="performance" />
  <connect from_op="Log" from_port="through 3" to_port="result 2" />
  <portSpacing port="source_input 1" spacing="0" />
  <portSpacing port="source_input 2" spacing="0" />
  <portSpacing port="source_input 3" spacing="0" />
  <portSpacing port="sink_performance" spacing="0" />
  <portSpacing port="sink_result 1" spacing="0" />
  <portSpacing port="sink_result 2" spacing="0" />
  <portSpacing port="sink_result 3" spacing="0" />
  <portSpacing port="sink_result 4" spacing="0" />
  </process>
  <connect from_op="TrainData" from_port="output" to_op="Ztransformation" to_port="example set input" />
  <connect from_op="Ztransformation" from_port="example set output" to_op="IOStorer" to_port="store" />
  <connect from_op="Ztransformation" from_port="preprocessing model" to_op="ParameterOptimization" to_port="input 2" />
  <connect from_op="IOStorer" from_port="stored" to_op="ParameterOptimization" to_port="input 1" />
  <connect from_op="ParameterOptimization" from_port="performance" to_port="result 1" />
  <connect from_op="ParameterOptimization" from_port="parameter" to_port="result 2" />
  <connect from_op="ParameterOptimization" from_port="result 1" to_port="result 3" />
  <connect from_op="ParameterOptimization" from_port="result 2" to_port="result 4" />
  <connect from_op="ParameterOptimization" from_port="result 3" to_port="result 5" />
  <portSpacing port="sink_result 5" spacing="0" />
  <portSpacing port="sink_result 6" spacing="0" />
  </process>
  </process>
  • land
    land New Altair Community Member
    please switch to the XML View of RapidMiner to see the process as text. Then copy it to the clip board and paste it here, since the Internet Explorer representation contains these "-" signs, that are not allowed in XML.  I will then try to reproduce the behavior and check if there's a bug.
    Greetings,
      Sebastian
  • funnyhat
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
        <description> </description>
        <parameter key="logverbosity" value="3"/>
        <parameter key="send_mail" value="1"/>
            <parameter key="target_function" value="random classification"/>
            <parameter key="number_examples" value="100"/>
            <parameter key="number_of_attributes" value="5"/>
            <parameter key="attributes_lower_bound" value="-10.0"/>
            <parameter key="attributes_upper_bound" value="10.0"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
            <parameter key="datamanagement" value="0"/>
            <parameter key="return_preprocessing_model" value="true"/>
            <parameter key="create_view" value="false"/>
            <parameter key="attribute_filter_type" value="0"/>
            <parameter key="attribute" value=""/>
            <parameter key="value_type" value="0"/>
            <parameter key="except_value_type" value="2"/>
            <parameter key="block_type" value="0"/>
            <parameter key="except_block_type" value="2"/>
            <parameter key="method" value="0"/>
            <parameter key="min" value="0.0"/>
            <parameter key="max" value="1.0"/>
            <parameter key="name" value="data"/>
            <parameter key="io_object" value="ExampleSet"/>
            <parameter key="store_which" value="1"/>
            <parameter key="remove_from_process" value="false"/>
              <parameter key="Training.gamma" value="[0.0;1024;16;quadratic]"/>
              <parameter key="Training.C" value="[0.0;1000;10;quadratic]"/>
            </list>
                <parameter key="create_complete_model" value="false"/>
                <parameter key="average_performances_only" value="true"/>
                <parameter key="leave_one_out" value="false"/>
                <parameter key="number_of_validations" value="10"/>
                <parameter key="sampling_type" value="shuffled sampling"/>
                    <parameter key="svm_type" value="0"/>
                    <parameter key="kernel_type" value="2"/>
                    <parameter key="degree" value="5"/>
                    <parameter key="gamma" value="1024.0"/>
                    <parameter key="coef0" value="0.0"/>
                    <parameter key="C" value="1000.0"/>
                    <parameter key="nu" value="0.5"/>
                    <parameter key="cache_size" value="80"/>
                    <parameter key="epsilon" value="0.01"/>
                    <parameter key="p" value="0.1"/>
                    <list key="class_weights"/>
                    <parameter key="shrinking" value="true"/>
                    <parameter key="calculate_confidences" value="false"/>
                    <parameter key="confidence_for_multiclass" value="true"/>
                  <connect from_port="training" to_op="Training" to_port="training set"/>
                  <connect from_op="Training" from_port="model" to_port="model"/>
                  <portSpacing port="source_training" spacing="0"/>
                </process>
                    <parameter key="main_criterion" value="AUC"/>
                    <parameter key="accuracy" value="true"/>
                    <parameter key="classification_error" value="false"/>
                    <parameter key="kappa" value="false"/>
                    <parameter key="AUC (optimistic)" value="false"/>
                    <parameter key="AUC" value="true"/>
                    <parameter key="AUC (pessimistic)" value="false"/>
                    <parameter key="precision" value="false"/>
                    <parameter key="recall" value="false"/>
                    <parameter key="lift" value="false"/>
                    <parameter key="fallout" value="false"/>
                    <parameter key="f_measure" value="false"/>
                    <parameter key="false_positive" value="false"/>
                    <parameter key="false_negative" value="false"/>
                    <parameter key="true_positive" value="false"/>
                    <parameter key="true_negative" value="false"/>
                    <parameter key="sensitivity" value="false"/>
                    <parameter key="specificity" value="false"/>
                    <parameter key="youden" value="false"/>
                    <parameter key="positive_predictive_value" value="false"/>
                    <parameter key="negative_predictive_value" value="false"/>
                    <parameter key="psep" value="false"/>
                    <parameter key="skip_undefined_labels" value="true"/>
                    <parameter key="use_example_weights" value="true"/>
                  <connect from_port="model" to_op="Test" to_port="model"/>
                  <connect from_port="test set" to_op="Test" to_port="unlabelled data"/>
                  <connect from_op="Test" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
                  <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/>
                  <portSpacing port="sink_averagable 1" spacing="0"/>
                  <portSpacing port="sink_averagable 2" spacing="0"/>
                </process>
                <parameter key="filename" value="paraopt.log"/>
                <list key="log">
                  <parameter key="C" value="operator.Training.parameter.C"/>
                  <parameter key="Gamma" value="operator.Training.parameter.gamma"/>
                  <parameter key="absolute" value="operator.BinominalClassificationPerformance.value.performance"/>
                  <parameter key="auc" value="operator.Final Performance.value.AUC"/>
                </list>
                <parameter key="sorting_type" value="0"/>
                <parameter key="sorting_k" value="100"/>
                <parameter key="persistent" value="false"/>
              <connect from_port="input 1" to_op="Validation" to_port="training"/>
              <connect from_port="input 2" to_op="Log" to_port="through 3"/>
              <connect from_op="Validation" from_port="training" to_op="Log" to_port="through 1"/>
              <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 2"/>
              <connect from_op="Log" from_port="through 1" to_port="result 1"/>
              <connect from_op="Log" from_port="through 2" to_port="performance"/>
              <connect from_op="Log" from_port="through 3" to_port="result 2"/>
              <portSpacing port="source_input 3" spacing="0"/>
              <portSpacing port="sink_performance" spacing="0"/>
            </process>
          <connect from_op="TrainData" from_port="output" to_op="Ztransformation" to_port="example set input"/>
          <connect from_op="Ztransformation" from_port="example set output" to_op="IOStorer" to_port="store"/>
          <connect from_op="Ztransformation" from_port="preprocessing model" to_op="ParameterOptimization" to_port="input 2"/>
          <connect from_op="IOStorer" from_port="stored" to_op="ParameterOptimization" to_port="input 1"/>
          <connect from_op="ParameterOptimization" from_port="performance" to_port="result 1"/>
          <connect from_op="ParameterOptimization" from_port="parameter" to_port="result 2"/>
          <connect from_op="ParameterOptimization" from_port="result 1" to_port="result 3"/>
          <connect from_op="ParameterOptimization" from_port="result 2" to_port="result 4"/>
          <connect from_op="ParameterOptimization" from_port="result 3" to_port="result 5"/>
          <portSpacing port="sink_result 5" spacing="0"/>
          <portSpacing port="sink_result 6" spacing="0"/>
        </process>
    </process>
    I hope this time works, Great Thanks!!
  • land
    seems to me to deliver the best performance anyway? Or what do you want to the algorithm do, if you serve completely random data? learning the random seed? Possible, but more complex...
    Greetings,
      Sebastian
  • funnyhat
    Very, very strange. I am using the version 5.0.005 without any extension
    I can not upload the result pictures here, but the accuracy table is
    accuracy 58.00% +- 16.61%
                              true negative      true positive
    pred. negative    58                    42
    pred. positive      0                        0
    class recal          100%                0.00%
    I am really confused.. thanks
  • land
    it's really simple: The data you are trying to learn from is completely random. There is no statistical dependency between the attribute values and the label. Without such an dependency, you cannot predict the label based on the attribute values, because they simply are completely independent from the label value. So the best thing you can do is predicting always the most frequent class.
    And exactly this is done by the SVM.
    To have more sexier results, change the parameter of the data generator to something different, that does not contain "random" in it's name.
    Greetings,
      Sebastian
  • funnyhat
    Great thanks !!! I over estimated the ability of SVM. I thought it can find something out anyway. I will try it with some other dataset anyhow, by the way, I Hope the SVM can pick out some attribites weights and generate a better model....Also , I hope my 5.0.005 version is not so bad compare to the current updated version.
  • funnyhat
    Something more, I noticed in the log file, it said s PM warning: performance criterion AUC was already part of performance vector, overwritten.... I hope this wont harm .
  • land
    what exactly is the problem with the current 5.0.006 version?
    Greetings,
      Sebastian
  • funnyhat
    I can not upgrade due to administrion rights. - just a local problem, which I can solve it by buying a new computer. Anyhow, have a nice weekend, besides, if you have time, please check during the optimization, if AUC is selected as main critia, it can not proper show in the performance results. But I am not so sure about it so far. . Have a nice weekend
  • IngoRM
    IngoRM New Altair Community Member
    just quickly jumping in:
    I think it is exactly the strength of SVM to not fit the model to random data - this reduces the risk for overfitting. A neural net, for example, can easily be tuned to learn the random data (or "to memorize" it...) but this is exactly the reason why I prefer SVM over NN  ;D
    Just my 2c. Cheers,
    Ingo
