I am currently giving a try at rapidminer for time series prediction.
I have a setup where I make a windowed data set, and make a prediction for the next event in my time series.
I would like to save as CSV the prediction, but the CSV writer does not support appending apparently, and overwrites the file for each new prediction made. Is there a way to do this easily? I am sure there are far better processes to do something like this...
Thank you
Alexandre
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="710" width="1518">
<operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30">
<parameter key="file_name" value="/home/cesari/eclipse/Grid/MyStrategies/marketData/EURODOLLAR_Five_Minutes.csv"/>
<parameter key="use_quotes" value="false"/>
<parameter key="column_separators" value=";"/>
<parameter key="date_format" value="/MM/dd HH:mm:ss.SSS"/>
<operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV (2)" width="90" x="45" y="255">
<parameter key="file_name" value="/home/cesari/eclipse/Grid/grid-analysis/results/Positions.csv"/>
<operator activated="true" class="discretize_by_user_specification" expanded="true" height="94" name="Discretize" width="90" x="179" y="255">
<parameter key="attribute" value="Value"/>
<list key="classes">
<parameter key="short" value="-1.0"/>
<parameter key="flat" value="0.0"/>
<parameter key="long" value="1.0"/>
</list>
<operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (2)" width="90" x="308" y="255">
<parameter key="name" value="date"/>
<operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="308" y="30">
<parameter key="name" value="Date"/>
<operator activated="true" class="join" expanded="true" height="76" name="Join" width="90" x="442" y="30"/>
<operator activated="true" class="set_role" expanded="true" height="76" name="Set Role (3)" width="90" x="576" y="30">
<parameter key="name" value="Value"/>
<operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="718" y="32">
<parameter key="attributes" value="date|Value|Open|Low|High|Close"/>
<operator activated="true" class="multiply" expanded="true" height="76" name="Multiply" width="90" x="884" y="31"/>
<operator activated="true" class="series:windowing" expanded="true" height="76" name="Windowing" width="90" x="1050" y="30">
<parameter key="horizon" value="1"/>
<parameter key="window_size" value="200"/>
<parameter key="create_label" value="true"/>
<parameter key="label_attribute" value="Value"/>
<operator activated="true" class="series:sliding_window_validation" expanded="true" height="112" name="Validation" width="90" x="1251" y="30">
<parameter key="training_window_width" value="50"/>
<parameter key="test_window_width" value="1"/>
<process expanded="true" height="673" width="419">
<operator activated="true" class="support_vector_machine_libsvm" expanded="true" height="76" name="SVM" width="90" x="179" y="30">
<parameter key="gamma" value="0.2"/>
<parameter key="C" value="0.5"/>
<parameter key="cache_size" value="200"/>
<list key="class_weights"/>
<connect from_port="training" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="multiply" expanded="true" height="94" name="Multiply (2)" width="90" x="45" y="210"/>
<operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes (2)" width="90" x="112" y="390">
<parameter key="attribute" value="prediction(label)"/>
<parameter key="attributes" value="prediction(label)"/>
<operator activated="true" class="write_csv" expanded="true" height="60" name="Write CSV" width="90" x="255" y="399">
<parameter key="csv_file" value="/home/cesari/Bureau/previsions.csv"/>
<operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="246" y="30"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Performance" to_port="labelled data"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Write CSV" to_port="input"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_op="Read CSV" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Read CSV (2)" from_port="output" to_op="Discretize" to_port="example set input"/>
<connect from_op="Discretize" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="right"/>
<connect from_op="Set Role" from_port="example set output" to_op="Join" to_port="left"/>
<connect from_op="Join" from_port="join" to_op="Set Role (3)" to_port="example set input"/>
<connect from_op="Set Role (3)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Windowing" to_port="example set input"/>
<connect from_op="Windowing" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 1"/>
</process>
</process>
