Can I change the default unit of milimeter (mm) into meter (m)? and how to do it?
Thanks
See http://forum.altairhyperworks.com/index.php?/topic/2524-what-are-the-units-used-in-otpistruct/?hl=units
I already setup material properties with value according SI unit as below:
E = in pascal (Pa)
NU = unitless
Density = kg/m^3
Then, run modal analysis. But has below error.
You need to add DTI UNITS card.
Go to Control cards>> DTI_UNITS>> input the same unit system which you have used for modelling and run the analysis.
