<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Root"> <process expanded="true" height="638" width="573"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="rename_by_replacing" expanded="true" height="76" name="rename" width="90" x="45" y="120"> <parameter key="replace_what" value="attribute_"/> <parameter key="replace_by" value="a"/> </operator> <operator activated="true" class="split_data" expanded="true" height="94" name="split" width="90" x="179" y="30"> <enumeration key="partitions"> <parameter key="ratio" value="0.5"/> <parameter key="ratio" value="0.5"/> </enumeration> </operator> <operator activated="true" class="optimize_selection" expanded="true" height="94" name="FS" width="90" x="313" y="30"> <process expanded="true" height="638" width="573"> <operator activated="true" class="select_attributes" expanded="true" height="76" name="no special" width="90" x="45" y="30"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="class"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="execute_script" expanded="true" height="76" name="Execute Script" width="90" x="179" y="30"> <parameter key="script" value="ExampleSet exampleSet = operator.getInput(ExampleSet.class); String atts = ""; for (Attribute attribute : exampleSet.getAttributes()) { String name = attribute.getName(); 	atts = atts + " " + name; } operator.getProcess().getMacroHandler().addMacro("atts", atts)"/> </operator> <operator activated="true" class="weka:W-J48" expanded="true" height="76" name="W-J48" width="90" x="179" y="165"/> <operator activated="true" class="apply_model" expanded="true" height="76" name="Applier" width="90" x="112" y="300"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="246" y="300"/> <operator activated="true" class="provide_macro_as_log_value" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="313" y="30"> <parameter key="macro_name" value="atts"/> </operator> <operator activated="true" class="log" expanded="true" height="94" name="MyLog" width="90" x="380" y="120"> <list key="log"> <parameter key="generation" value="operator.FS.value.generation"/> <parameter key="performance" value="operator.Performance.value.performance"/> <parameter key="atts" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> </operator> <connect from_port="example set" to_op="no special" to_port="example set input"/> <connect from_port="through 1" to_op="Applier" to_port="unlabelled data"/> <connect from_op="no special" from_port="example set output" to_op="Execute Script" to_port="input 1"/> <connect from_op="no special" from_port="original" to_op="W-J48" to_port="training set"/> <connect from_op="Execute Script" from_port="output 1" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="W-J48" from_port="model" to_op="Applier" to_port="model"/> <connect from_op="Applier" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_op="MyLog" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="MyLog" to_port="through 2"/> <connect from_op="MyLog" from_port="through 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="log_to_data" expanded="true" height="94" name="Log to Data" width="90" x="447" y="120"> <parameter key="log_name" value="MyLog"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="rename" to_port="example set input"/> <connect from_op="rename" from_port="example set output" to_op="split" to_port="example set"/> <connect from_op="split" from_port="partition 1" to_op="FS" to_port="example set in"/> <connect from_op="split" from_port="partition 2" to_op="FS" to_port="through 1"/> <connect from_op="FS" from_port="weights" to_port="result 1"/> <connect from_op="FS" from_port="performance" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="338" width="616"> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="optimize_selection_forward" compatibility="5.0.10" expanded="true" height="94" name="First Round" width="90" x="179" y="30"> <parameter key="maximal_number_of_attributes" value="25"/> <parameter key="speculative_rounds" value="3"/> <process expanded="true" height="597" width="804"> <operator activated="true" class="materialize_data" compatibility="5.0.10" expanded="true" height="76" name="Materialize Data" width="90" x="45" y="30"/> <operator activated="true" class="x_validation" compatibility="5.0.10" expanded="true" height="112" name="Validation" width="90" x="179" y="30"> <process expanded="true" height="615" width="377"> <operator activated="true" class="normalize" compatibility="5.0.10" expanded="true" height="94" name="Normalize" width="90" x="45" y="30"> <parameter key="create_view" value="true"/> </operator> <operator activated="true" class="linear_regression" compatibility="5.0.10" expanded="true" height="94" name="Linear Regression" width="90" x="179" y="30"> <parameter key="feature_selection" value="none"/> <parameter key="eliminate_colinear_features" value="false"/> </operator> <connect from_port="training" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Linear Regression" to_port="training set"/> <connect from_op="Normalize" from_port="preprocessing model" to_port="through 1"/> <connect from_op="Linear Regression" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <portSpacing port="sink_through 2" spacing="0"/> </process> <process expanded="true" height="615" width="413"> <operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model (2)" width="90" x="66" y="104"> <list key="application_parameters"/> <parameter key="create_view" value="true"/> </operator> <operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.0.10" expanded="true" height="76" name="Performance" width="90" x="313" y="30"> <parameter key="absolute_error" value="true"/> <parameter key="squared_correlation" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_port="through 1" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.0.10" expanded="true" height="76" name="Log" width="90" x="380" y="30"> <list key="log"> <parameter key="numberOfAttributes" value="operator.First Round.value.number of attributes"/> <parameter key="attributes" value="operator.First Round.value.feature_names"/> <parameter key="absolute error" value="operator.Validation.value.performance2"/> <parameter key="std" value="operator.Validation.value.deviation"/> <parameter key="sqrd cor" value="operator.Validation.value.performance3"/> </list> </operator> <connect from_port="example set" to_op="Materialize Data" to_port="example set input"/> <connect from_op="Materialize Data" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="First Round" to_port="example set"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
