<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="251" width="748"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Labor-Negotiations"/> </operator> <operator activated="true" class="rename_by_replacing" expanded="true" height="76" name="Rename by Replacing" width="90" x="179" y="30"> <parameter key="replace_what" value="-"/> <parameter key="replace_by" value="_"/> </operator> <operator activated="true" class="generate_empty_attribute" expanded="true" height="76" name="Generate Empty Attribute" width="90" x="313" y="30"> <parameter key="name" value="numberOfMissings"/> </operator> <operator activated="true" class="replace_missing_values" expanded="true" height="94" name="Replace Missing Values" width="90" x="447" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="numberOfMissings"/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="loop_attributes" expanded="true" height="60" name="Loop Attributes" width="90" x="581" y="30"> <parameter key="iteration_macro" value="currentAttribute"/> <process expanded="true" height="581" width="764"> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="45" y="30"> <list key="function_descriptions"> <parameter key="newNumberOfMissings" value="numberOfMissings + if(%{currentAttribute}!=%{currentAttribute},1,0)"/> </list> </operator> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="numberOfMissings"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="313" y="30"> <parameter key="old_name" value="newNumberOfMissings"/> <parameter key="new_name" value="numberOfMissings"/> </operator> <connect from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Generate Empty Attribute" to_port="example set input"/> <connect from_op="Generate Empty Attribute" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros> <macro> <key/> <value/> </macro> </macros> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="353" width="808"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Labor-Negotiations"/> </operator> <operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="179" y="30"/> <operator activated="true" class="generate_id" expanded="true" height="76" name="Original Data" width="90" x="380" y="120"/> <operator activated="true" class="subprocess" expanded="true" height="76" name="Missing Count Column" width="90" x="380" y="30"> <process expanded="true" height="353" width="748"> <operator activated="true" class="transpose" expanded="true" height="76" name="Transpose" width="90" x="180" y="30"/> <operator activated="true" class="loop_attributes" expanded="true" height="60" name="Loop Attributes" width="90" x="315" y="30"> <process expanded="true" height="353" width="808"> <operator activated="true" class="extract_macro" expanded="true" height="60" name="Count unknowns" width="90" x="45" y="30"> <parameter key="macro" value="Count"/> <parameter key="macro_type" value="statistics"/> <parameter key="statistics" value="unknown"/> <parameter key="attribute_name" value="%{loop_attribute}"/> <parameter key="example_index" value="%{b}"/> </operator> <operator activated="true" class="provide_macro_as_log_value" expanded="true" height="76" name="Provide Count as Log Value" width="90" x="180" y="30"> <parameter key="macro_name" value="Total"/> </operator> <operator activated="true" class="log" expanded="true" height="76" name="Log" width="90" x="494" y="30"> <list key="log"> <parameter key="Missings" value="operator.Count unknowns.value.macro_value"/> </list> </operator> <connect from_port="example set" to_op="Count unknowns" to_port="example set"/> <connect from_op="Count unknowns" from_port="example set" to_op="Provide Count as Log Value" to_port="through 1"/> <connect from_op="Provide Count as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="log_to_data" expanded="true" height="94" name="Log to Data" width="90" x="179" y="165"/> <operator activated="true" class="parse_numbers" expanded="true" height="76" name="Parse Numbers" width="90" x="313" y="165"/> <operator activated="true" class="generate_id" expanded="true" height="76" name="Generate ID" width="90" x="447" y="165"/> <connect from_port="in 1" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="join" expanded="true" height="76" name="Data plus Missing Count" width="90" x="565" y="31"/> <connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Missing Count Column" to_port="in 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Original Data" to_port="example set input"/> <connect from_op="Original Data" from_port="example set output" to_op="Data plus Missing Count" to_port="right"/> <connect from_op="Missing Count Column" from_port="out 1" to_op="Data plus Missing Count" to_port="left"/> <connect from_op="Data plus Missing Count" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
The computer scientist in me wants to answer: Transpose the ExampleSet and solve the old attribute problem, transpose it again and the things are cleared. But it doesn't seem to be appropriate
