<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="476" width="681"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="text:data_to_documents" expanded="true" height="60" name="Data to Documents" width="90" x="179" y="75"> <list key="specify_weights"/> </operator> <operator activated="true" class="text:process_documents" expanded="true" height="94" name="Process Documents" width="90" x="514" y="120"> <process expanded="true" height="583" width="773"> <operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="246" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="54"/> </process> </operator></process>
