Groovy script request
Could someone show me a groovy script which can roughly do the same thing as the "Moving Average" operator?
I hope that a script will make it more easy to make useful attributes.
For example create the attributes: "MA2_att1 - MA9_att1" and "MA2_att2 - MA9_att2".
I know you can also do this with basic RM operators, (see the script below) but having to rename all is rather cumbersome.
Also it is hard to create a wide range of functions.
RM xml code: generates a sinus time series with noise, and creates some derived attributes
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="573" width="975">
<operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
<parameter key="target_function" value="driller oscillation timeseries"/>
<parameter key="attributes_lower_bound" value="-1.0"/>
<parameter key="attributes_upper_bound" value="1.0"/>
<operator activated="true" class="add_noise" expanded="true" height="94" name="Add Noise" width="90" x="180" y="30">
<parameter key="label_noise" value="0.0"/>
<parameter key="default_attribute_noise" value="0.3"/>
<list key="noise"/>
<operator activated="true" class="series:moving_average" expanded="true" height="76" name="MA:9 att1" width="90" x="315" y="30">
<parameter key="attribute_name" value="att1"/>
<parameter key="window_width" value="9"/>
<operator activated="true" class="rename_by_replacing" expanded="true" height="76" name="MA9" width="90" x="450" y="30">
<parameter key="replace_what" value="moving_average\("/>
<parameter key="replace_by" value="MA9_"/>
<operator activated="true" class="series:moving_average" expanded="true" height="76" name="MA:2 att1" width="90" x="585" y="30">
<parameter key="window_width" value="2"/>
<operator activated="true" class="rename_by_replacing" expanded="true" height="76" name="MA2" width="90" x="720" y="30">
<parameter key="replace_by" value="MA2_"/>
<operator activated="true" class="series:moving_average" expanded="true" height="76" name="MA:9 att2" width="90" x="855" y="30">
<parameter key="attribute_name" value="att2"/>
<operator activated="true" class="rename_by_replacing" expanded="true" height="76" name="MA9 (2)" width="90" x="45" y="120">
<operator activated="true" class="series:moving_average" expanded="true" height="76" name="MA:2 att2" width="90" x="180" y="120">
<operator activated="true" class="rename_by_replacing" expanded="true" height="76" name="MA2 (2)" width="90" x="315" y="120">
<operator activated="true" class="rename_by_replacing" expanded="true" height="76" name="rem \)" width="90" x="450" y="120">
<parameter key="replace_what" value="\)"/>
<operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="585" y="120">
<parameter key="MA2_att1 - MA9_att1" value="MA2_att1 - MA9_att1"/>
<parameter key="MA2_att2 - MA9_att2" value="MA2_att2 - MA9_att2"/>
</list>
<operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="720" y="120">
<parameter key="attribute" value="att5"/>
<connect from_op="Generate Data" from_port="output" to_op="Add Noise" to_port="example set input"/>
<connect from_op="Add Noise" from_port="example set output" to_op="MA:9 att1" to_port="example set input"/>
<connect from_op="MA:9 att1" from_port="example set output" to_op="MA9" to_port="example set input"/>
<connect from_op="MA9" from_port="example set output" to_op="MA:2 att1" to_port="example set input"/>
<connect from_op="MA:2 att1" from_port="example set output" to_op="MA2" to_port="example set input"/>
<connect from_op="MA2" from_port="example set output" to_op="MA:9 att2" to_port="example set input"/>
<connect from_op="MA:9 att2" from_port="example set output" to_op="MA9 (2)" to_port="example set input"/>
<connect from_op="MA9 (2)" from_port="example set output" to_op="MA:2 att2" to_port="example set input"/>
<connect from_op="MA:2 att2" from_port="example set output" to_op="MA2 (2)" to_port="example set input"/>
<connect from_op="MA2 (2)" from_port="example set output" to_op="rem \)" to_port="example set input"/>
<connect from_op="rem \)" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="90"/>
</process>
</process>
Comments
No comments on this post.
