<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="583" width="878"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="184" y="284"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="385" y="289"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Outlook"/> <parameter key="invert_selection" value="true"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
