<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros> <macro> <key/> <value/> </macro> </macros> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="428" width="815"> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="file_name" value="C:\Users\Alejandro\Desktop\ToSinc\Austral\Tesis\Security\ParcerCVSNVD\Data\nvdcve-2.0-2009.csv"/> <parameter key="skip_comments" value="false"/> <parameter key="use_quotes" value="false"/> <parameter key="column_separators" value=",\s*"/> </operator> <operator activated="false" class="sample_stratified" expanded="true" height="76" name="Sample (Stratified)" width="90" x="45" y="120"> <parameter key="sample_size" value="10"/> </operator> <operator activated="true" class="nominal_to_text" expanded="true" height="76" name="Nominal to Text" width="90" x="45" y="255"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Summary"/> </operator> <operator activated="true" class="nominal_to_text" expanded="true" height="76" name="Nominal to Text (2)" width="90" x="179" y="255"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="CompromisedSoftware"/> </operator> <operator activated="true" class="text:process_document_from_data" expanded="true" height="76" name="Process Documents from Data" width="90" x="179" y="30"> <parameter key="prune_method" value="percentual"/> <list key="specify_weights"/> <process expanded="true" height="393" width="633"> <operator activated="true" class="text:transform_cases" expanded="true" height="60" name="Transform Cases" width="90" x="112" y="75"/> <operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="246" y="75"/> <operator activated="true" class="text:stem_snowball" expanded="true" height="60" name="Stem (Snowball)" width="90" x="380" y="75"/> <operator activated="true" class="text:filter_stopwords_english" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="514" y="75"/> <connect from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="54"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" breakpoints="after" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="313" y="165"> <parameter key="name" value="vuln:cwe"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="optimize_parameters_evolutionary" expanded="true" height="112" name="Optimize Parameters (Evolutionary)" width="90" x="514" y="210"> <list key="parameters"> <parameter key="Decision Tree (2).confidence" value="[1.0E-7;0.5]"/> </list> <process expanded="true" height="365" width="569"> <operator activated="true" class="polynomial_by_binomial_classification" expanded="true" height="76" name="Polynomial by Binomial Classification" width="90" x="112" y="120"> <process expanded="true" height="383" width="587"> <operator activated="true" breakpoints="after" class="split_validation" expanded="true" height="112" name="Validation (2)" width="90" x="246" y="75"> <process expanded="true" height="383" width="279"> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree (2)" width="90" x="89" y="30"> <parameter key="confidence" value="0.11025199457227444"/> </operator> <connect from_port="training" to_op="Decision Tree (2)" to_port="training set"/> <connect from_op="Decision Tree (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="383" width="279"> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" breakpoints="after" class="performance_binominal_classification" expanded="true" height="76" name="Performance (2)" width="90" x="45" y="120"> <parameter key="main_criterion" value="AUC"/> <parameter key="false_positive" value="true"/> <parameter key="false_negative" value="true"/> <parameter key="true_positive" value="true"/> <parameter key="true_negative" value="true"/> </operator> <operator activated="true" class="log" expanded="true" height="76" name="Log" width="90" x="179" y="75"> <parameter key="filename" value="logTest.log"/> <list key="log"> <parameter key="confidence" value="operator.Decision Tree (2).parameter.confidence"/> <parameter key="AUC" value="operator.Performance (2).value.AUC"/> <parameter key="FN" value="operator.Performance (2).value.false_negative"/> <parameter key="FP" value="operator.Performance (2).value.false_positive"/> <parameter key="TN" value="operator.Performance (2).value.true_negative"/> <parameter key="TP" value="operator.Performance (2).value.true_positive"/> <parameter key="Accuracy" value="operator.Performance (2).value.accuracy"/> </list> <parameter key="persistent" value="true"/> </operator> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="training set" to_op="Validation (2)" to_port="training"/> <connect from_op="Validation (2)" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="246" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" expanded="true" height="76" name="Performance" width="90" x="447" y="210"> <list key="class_weights"/> </operator> <connect from_port="input 1" to_op="Polynomial by Binomial Classification" to_port="training set"/> <connect from_op="Polynomial by Binomial Classification" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Polynomial by Binomial Classification" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_port="result 1"/> <connect from_op="Performance" from_port="performance" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Read CSV" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Nominal to Text (2)" to_port="example set input"/> <connect from_op="Nominal to Text (2)" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Optimize Parameters (Evolutionary)" to_port="input 1"/> <connect from_op="Optimize Parameters (Evolutionary)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Evolutionary)" from_port="result 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros> <macro> <key/> <value/> </macro> </macros> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="428" width="815"> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="file_name" value="C:\Users\Alejandro\Desktop\ToSinc\Austral\Tesis\Security\ParcerCVSNVD\Data\nvdcve-2.0-2009.csv"/> <parameter key="skip_comments" value="false"/> <parameter key="use_quotes" value="false"/> <parameter key="column_separators" value=",\s*"/> </operator> <operator activated="false" class="sample_stratified" expanded="true" height="76" name="Sample (Stratified)" width="90" x="45" y="120"> <parameter key="sample_size" value="10"/> </operator> <operator activated="true" class="nominal_to_text" expanded="true" height="76" name="Nominal to Text" width="90" x="45" y="255"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Summary"/> </operator> <operator activated="true" class="nominal_to_text" expanded="true" height="76" name="Nominal to Text (2)" width="90" x="179" y="255"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="CompromisedSoftware"/> </operator> <operator activated="true" class="text:process_document_from_data" expanded="true" height="76" name="Process Documents from Data" width="90" x="179" y="30"> <parameter key="prune_method" value="percentual"/> <list key="specify_weights"/> <process expanded="true" height="393" width="633"> <operator activated="true" class="text:transform_cases" expanded="true" height="60" name="Transform Cases" width="90" x="112" y="75"/> <operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="246" y="75"/> <operator activated="true" class="text:stem_snowball" expanded="true" height="60" name="Stem (Snowball)" width="90" x="380" y="75"/> <operator activated="true" class="text:filter_stopwords_english" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="514" y="75"/> <connect from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="54"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" breakpoints="after" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="313" y="165"> <parameter key="name" value="vuln:cwe"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="optimize_parameters_evolutionary" expanded="true" height="112" name="Optimize Parameters (Evolutionary)" width="90" x="514" y="210"> <list key="parameters"> <parameter key="Decision Tree (2).confidence" value="[1.0E-7;0.5]"/> </list> <process expanded="true" height="365" width="569"> <operator activated="true" class="polynomial_by_binomial_classification" expanded="true" height="76" name="Polynomial by Binomial Classification" width="90" x="112" y="120"> <process expanded="true" height="383" width="587"> <operator activated="true" breakpoints="after" class="split_validation" expanded="true" height="112" name="Validation (2)" width="90" x="246" y="75"> <process expanded="true" height="383" width="279"> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree (2)" width="90" x="89" y="30"> <parameter key="confidence" value="0.11025199457227444"/> </operator> <connect from_port="training" to_op="Decision Tree (2)" to_port="training set"/> <connect from_op="Decision Tree (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="460" width="426"> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" breakpoints="after" class="performance_binominal_classification" expanded="true" height="76" name="Performance (2)" width="90" x="45" y="120"> <parameter key="main_criterion" value="AUC"/> <parameter key="false_positive" value="true"/> <parameter key="false_negative" value="true"/> <parameter key="true_positive" value="true"/> <parameter key="true_negative" value="true"/> </operator> <operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples" width="90" x="45" y="255"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label!=other"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="extract_macro" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="255"> <parameter key="macro" value="currentLabel"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="label"/> <parameter key="example_index" value="1"/> </operator> <operator activated="true" class="provide_macro_as_log_value" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="313" y="255"> <parameter key="macro_name" value="currentLabel"/> </operator> <operator activated="true" class="log" expanded="true" height="94" name="Log" width="90" x="313" y="75"> <parameter key="filename" value="logTest.log"/> <list key="log"> <parameter key="confidence" value="operator.Decision Tree (2).parameter.confidence"/> <parameter key="AUC" value="operator.Performance (2).value.AUC"/> <parameter key="FN" value="operator.Performance (2).value.false_negative"/> <parameter key="FP" value="operator.Performance (2).value.false_positive"/> <parameter key="TN" value="operator.Performance (2).value.true_negative"/> <parameter key="TP" value="operator.Performance (2).value.true_positive"/> <parameter key="Accuracy" value="operator.Performance (2).value.accuracy"/> <parameter key="currentLabel" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> <parameter key="persistent" value="true"/> </operator> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_op="Log" to_port="through 1"/> <connect from_op="Performance (2)" from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 2"/> <connect from_op="Log" from_port="through 1" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="training set" to_op="Validation (2)" to_port="training"/> <connect from_op="Validation (2)" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="246" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" expanded="true" height="76" name="Performance" width="90" x="447" y="210"> <list key="class_weights"/> </operator> <connect from_port="input 1" to_op="Polynomial by Binomial Classification" to_port="training set"/> <connect from_op="Polynomial by Binomial Classification" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Polynomial by Binomial Classification" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_port="result 1"/> <connect from_op="Performance" from_port="performance" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Read CSV" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Nominal to Text (2)" to_port="example set input"/> <connect from_op="Nominal to Text (2)" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Optimize Parameters (Evolutionary)" to_port="input 1"/> <connect from_op="Optimize Parameters (Evolutionary)" from_port="performance" to_port="result 1"/> <connect from_op="Optimize Parameters (Evolutionary)" from_port="result 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
