<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="651" width="722"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="210"> <parameter key="repository_entry" value="//Samples/data/Golf-Testset"/> </operator> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve (3)" width="90" x="15" y="89"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree" width="90" x="179" y="30"/> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="246" y="210"> <list key="application_parameters"/> </operator> <operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="380" y="210"/> <operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples" width="90" x="581" y="255"> <parameter key="condition_class" value="wrong_predictions"/> </operator> <operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="447" y="30"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Retrieve (3)" from_port="output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Performance" to_port="labelled data"/> <connect from_op="Multiply" from_port="output 2" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 2"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
