I cannot build RapidMiner 5.0 (from the contents of file rapidminer-5.0.zip). I have tried it three different ways:
1. Ant
C:\rapidminer>C:\Programme\apache-ant-1.8.0\bin\ant.bat -f build.xml build
Buildfile: C:\rapidminer\build.xml
version.get:
version.updateFiles:
[delete] Deleting: C:\rapidminer\src\com\rapidminer\Version.java
[echo] Updating to version 5.0.005
BUILD FAILED
C:\rapidminer\build.xml:484: The following error occurred while executing this line:
C:\rapidminer\build.xml:522: Warning:
Could not find file C:\rapidminer\licenses\short_license.txt to copy.
Total time: 0 seconds
2. Eclipse: Import project
Import -> Existing Projects into Workspace -> Choose directory rapidminer I have copied to workspace
Errors (1 item):
Description: This project needs to migrate WTP metadata
Resource: rapidminer
Path:
Type: ModuleCore Validation Marker
Warnings (446 items):
3. Eclipse: New Java Project from Existing Ant Buildfile
New -> Project -> Java Project from Existing Ant Buildfile -> Choose rapidminer\build.xml
Errors (119 items):
... (-see below-)
Warnings (458 items):
What am I doing wrong? Has anyone managed to get the build done?
With kind regards
eckstein
These are the errors I omitted above for readability:
Description Resource Path Location Type BadPaddingException cannot be resolved to a type CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 87 Java Problem BadPaddingException cannot be resolved to a type CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 121 Java Problem Cipher cannot be resolved CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 70 Java Problem Cipher cannot be resolved CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 71 Java Problem Cipher cannot be resolved CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 105 Java Problem Cipher cannot be resolved CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 106 Java Problem Cipher cannot be resolved to a type CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 70 Java Problem Cipher cannot be resolved to a type CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 105 Java Problem ClassDoc cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 137 Java Problem ClassDoc cannot be resolved to a type ProgramHTMLOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 42 Java Problem com.sun.tools cannot be resolved DocumentationGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 74 Java Problem IllegalBlockSizeException cannot be resolved to a type CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 85 Java Problem IllegalBlockSizeException cannot be resolved to a type CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 119 Java Problem KeyGenerator cannot be resolved KeyGeneratorTool.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 59 Java Problem KeyGenerator cannot be resolved to a type KeyGeneratorTool.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 57 Java Problem NoSuchPaddingException cannot be resolved to a type CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 81 Java Problem NoSuchPaddingException cannot be resolved to a type CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 113 Java Problem RootDoc cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 136 Java Problem RootDoc cannot be resolved to a type DocumentationGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 55 Java Problem RootDoc cannot be resolved to a type DocumentationGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 75 Java Problem RootDoc cannot be resolved to a type DocumentationGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 79 Java Problem RootDoc cannot be resolved to a type DocumentationGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 81 Java Problem RootDoc cannot be resolved to a type DocumentationGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 131 Java Problem RootDoc cannot be resolved to a type OperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 39 Java Problem RootDoc cannot be resolved to a type ProgramHTMLOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 41 Java Problem SecretKey cannot be resolved to a type KeyGeneratorTool.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 68 Java Problem SecretKeySpec cannot be resolved to a type KeyGeneratorTool.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 99 Java Problem SeeTag cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 247 Java Problem SeeTag cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 249 Java Problem SourcePosition cannot be resolved to a type XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 96 Java Problem Tag cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 151 Java Problem Tag cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 245 Java Problem Tag cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 310 Java Problem Tag cannot be resolved to a type CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 82 Java Problem Tag cannot be resolved to a type CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 86 Java Problem Tag cannot be resolved to a type CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 90 Java Problem Tag cannot be resolved to a type CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 94 Java Problem Tag cannot be resolved to a type MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 81 Java Problem Tag cannot be resolved to a type MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 85 Java Problem Tag cannot be resolved to a type MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 89 Java Problem Tag cannot be resolved to a type MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 93 Java Problem Tag cannot be resolved to a type RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 82 Java Problem Tag cannot be resolved to a type RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 92 Java Problem Tag cannot be resolved to a type RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 96 Java Problem Tag cannot be resolved to a type RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 100 Java Problem Tag cannot be resolved to a type RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 104 Java Problem Tag cannot be resolved to a type ReferenceTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 128 Java Problem Tag cannot be resolved to a type ReferenceTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 129 Java Problem Tag cannot be resolved to a type ReferenceTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 132 Java Problem Tag cannot be resolved to a type TexTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 35 Java Problem Tag cannot be resolved to a type TexTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 37 Java Problem Tag cannot be resolved to a type XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 87 Java Problem Tag cannot be resolved to a type XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 100 Java Problem Tag cannot be resolved to a type XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 122 Java Problem Tag cannot be resolved to a type XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 126 Java Problem Tag cannot be resolved to a type XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 139 Java Problem Taglet cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 112 Java Problem Taglet cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 112 Java Problem Taglet cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 130 Java Problem Taglet cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 131 Java Problem Taglet cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 132 Java Problem Taglet cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 133 Java Problem Taglet cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 270 Java Problem Taglet cannot be resolved to a type AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 270 Java Problem Taglet cannot be resolved to a type CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 73 Java Problem Taglet cannot be resolved to a type CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 75 Java Problem Taglet cannot be resolved to a type MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 72 Java Problem Taglet cannot be resolved to a type MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 74 Java Problem Taglet cannot be resolved to a type RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 73 Java Problem Taglet cannot be resolved to a type RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 75 Java Problem Taglet cannot be resolved to a type ReferenceTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 47 Java Problem Taglet cannot be resolved to a type ReferenceTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 119 Java Problem Taglet cannot be resolved to a type ReferenceTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 121 Java Problem Taglet cannot be resolved to a type TexTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 33 Java Problem Taglet cannot be resolved to a type XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 78 Java Problem Taglet cannot be resolved to a type XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 80 Java Problem The hierarchy of the type CiteTaglet is inconsistent CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 37 Java Problem The hierarchy of the type MathTaglet is inconsistent MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 36 Java Problem The hierarchy of the type RefTaglet is inconsistent RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 37 Java Problem The hierarchy of the type XMLExampleTaglet is inconsistent XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 42 Java Problem The import com.sun.javadoc cannot be resolved AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 49 Java Problem The import com.sun.javadoc cannot be resolved AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 50 Java Problem The import com.sun.javadoc cannot be resolved AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 51 Java Problem The import com.sun.javadoc cannot be resolved AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 52 Java Problem The import com.sun.javadoc cannot be resolved CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 27 Java Problem The import com.sun.javadoc cannot be resolved DocumentationGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 40 Java Problem The import com.sun.javadoc cannot be resolved MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 27 Java Problem The import com.sun.javadoc cannot be resolved OperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 28 Java Problem The import com.sun.javadoc cannot be resolved ProgramHTMLOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 31 Java Problem The import com.sun.javadoc cannot be resolved ProgramHTMLOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 32 Java Problem The import com.sun.javadoc cannot be resolved RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 27 Java Problem The import com.sun.javadoc cannot be resolved ReferenceTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 37 Java Problem The import com.sun.javadoc cannot be resolved TexTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 25 Java Problem The import com.sun.javadoc cannot be resolved XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 30 Java Problem The import com.sun.javadoc cannot be resolved XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 31 Java Problem The import com.sun.tools cannot be resolved AbstractOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 53 Java Problem The import com.sun.tools cannot be resolved CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 28 Java Problem The import com.sun.tools cannot be resolved MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 28 Java Problem The import com.sun.tools cannot be resolved RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 28 Java Problem The import com.sun.tools cannot be resolved ReferenceTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 38 Java Problem The import com.sun.tools cannot be resolved TexTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 26 Java Problem The import com.sun.tools cannot be resolved XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 32 Java Problem The import javax.crypto cannot be resolved CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 30 Java Problem The import javax.crypto cannot be resolved CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 31 Java Problem The import javax.crypto cannot be resolved CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 32 Java Problem The import javax.crypto cannot be resolved CipherTools.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 33 Java Problem The import javax.crypto cannot be resolved KeyGeneratorTool.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 35 Java Problem The import javax.crypto cannot be resolved KeyGeneratorTool.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 36 Java Problem The import javax.crypto cannot be resolved KeyGeneratorTool.java /RapidMiner_Vega/src/com/rapidminer/tools/cipher line 37 Java Problem The type CiteTaglet must implement the inherited abstract method TexTaglet.toTex(Tag) CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 37 Java Problem The type CiteTaglet must implement the inherited abstract method TexTaglet.toTex(Tag[]) CiteTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 37 Java Problem The type LatexOperatorDocGenerator must implement the inherited abstract method OperatorDocGenerator.generateDoc(Operator, RootDoc, PrintWriter) LatexOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 49 Java Problem The type MathTaglet must implement the inherited abstract method TexTaglet.toTex(Tag) MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 36 Java Problem The type MathTaglet must implement the inherited abstract method TexTaglet.toTex(Tag[]) MathTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 36 Java Problem The type ProgramHTMLOperatorDocGenerator must implement the inherited abstract method OperatorDocGenerator.generateDoc(Operator, RootDoc, PrintWriter) ProgramHTMLOperatorDocGenerator.java /RapidMiner_Vega/src/com/rapidminer/doc line 39 Java Problem The type RefTaglet must implement the inherited abstract method TexTaglet.toTex(Tag) RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 37 Java Problem The type RefTaglet must implement the inherited abstract method TexTaglet.toTex(Tag[]) RefTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 37 Java Problem The type XMLExampleTaglet must implement the inherited abstract method TexTaglet.toTex(Tag) XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 42 Java Problem The type XMLExampleTaglet must implement the inherited abstract method TexTaglet.toTex(Tag[]) XMLExampleTaglet.java /RapidMiner_Vega/src/com/rapidminer/doc line 42 Java Problem
