<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="566" width="480"> <operator activated="true" class="generate_direct_mailing_data" expanded="true" height="60" name="Generate Direct Mailing Data" width="90" x="45" y="30"/> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="discretize_by_user_specification" expanded="true" height="94" name="Discretize" width="90" x="45" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="age"/> <list key="classes"> <parameter key="Below 10" value="10.0"/> <parameter key="Between 10 and 19" value="19.0"/> <parameter key="Between 20 and 39" value="39.0"/> <parameter key="Between 40 and 49" value="49.0"/> <parameter key="Between 50 and 59" value="59.0"/> <parameter key="Over 60" value="Infinity"/> </list> </operator> <operator activated="true" class="generate_copy" expanded="true" height="76" name="Generate Copy" width="90" x="45" y="345"> <parameter key="attribute_name" value="age"/> <parameter key="new_name" value="age_value"/> </operator> <operator activated="true" class="map" expanded="true" height="76" name="Map" width="90" x="179" y="345"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="age_value"/> <list key="value_mappings"> <parameter key="Below 10" value="0"/> <parameter key="Between 10 and 19" value="5"/> <parameter key="Between 20 and 39" value="3"/> <parameter key="Between 40 and 49" value="2"/> <parameter key="Between 50 and 59" value="1"/> <parameter key="Over 60" value="0"/> </list> </operator> <operator activated="true" class="parse_numbers" expanded="true" height="76" name="Parse Numbers" width="90" x="313" y="345"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="age_value"/> </operator> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="45" y="480"> <list key="function_descriptions"> <parameter key="score" value="2 * age_value + 0.0001 * earnings"/> </list> </operator> <connect from_op="Generate Direct Mailing Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Generate Copy" to_port="example set input"/> <connect from_op="Generate Copy" from_port="example set output" to_op="Map" to_port="example set input"/> <connect from_op="Map" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="450"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
