<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="463" width="1083"> <operator activated="true" class="set_macros" expanded="true" height="60" name="Define Makros" width="90" x="45" y="30"> <list key="macros"> <parameter key="DataRoot" value="/home/jdoe/data/"/> </list> </operator> <operator activated="true" class="subprocess" expanded="true" height="76" name="Read Zd 15-25" width="90" x="45" y="120"> <process expanded="true" height="463" width="844"> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV (7)" width="90" x="112" y="30"> <description>Liest zwei CSV-Dateien ein und kombiniert die Example-Sets</description> <parameter key="file_name" value="%{DataRoot}/Hadron_4000_Zd_15_25.csv"/> </operator> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV (8)" width="90" x="112" y="210"> <description>Liest zwei CSV-Dateien ein und kombiniert die Example-Sets</description> <parameter key="file_name" value="%{DataRoot}/Gamma_4000_Zd_15_25.csv"/> </operator> <operator activated="true" class="append" expanded="true" height="94" name="Append (4)" width="90" x="315" y="30"/> <connect from_op="Read CSV (7)" from_port="output" to_op="Append (4)" to_port="example set 1"/> <connect from_op="Read CSV (8)" from_port="output" to_op="Append (4)" to_port="example set 2"/> <connect from_op="Append (4)" from_port="merged set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Mark Id" width="90" x="246" y="120"> <parameter key="name" value="idx"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Mark Label" width="90" x="374" y="120"> <parameter key="name" value="ExpectedLabel"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="remap_binominals" expanded="true" height="76" name="Remap Binominals" width="90" x="514" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="ExpectedLabel"/> <parameter key="include_special_attributes" value="true"/> <parameter key="negative_value" value="Gamma"/> <parameter key="positive_value" value="Hadron"/> </operator> <operator activated="true" class="naive_bayes" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="644" y="120"/> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (2)" width="90" x="779" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" breakpoints="after" class="performance_binominal_classification" expanded="true" height="76" name="Performance (2)" width="90" x="916" y="120"> <parameter key="main_criterion" value="accuracy"/> <parameter key="precision" value="true"/> <parameter key="recall" value="true"/> </operator> <connect from_op="Read Zd 15-25" from_port="out 1" to_op="Mark Id" to_port="example set input"/> <connect from_op="Mark Id" from_port="example set output" to_op="Mark Label" to_port="example set input"/> <connect from_op="Mark Label" from_port="example set output" to_op="Remap Binominals" to_port="example set input"/> <connect from_op="Remap Binominals" from_port="example set output" to_op="Naive Bayes (2)" to_port="training set"/> <connect from_op="Naive Bayes (2)" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Naive Bayes (2)" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="463" width="1083"> <operator activated="true" class="set_macros" expanded="true" height="60" name="Define Makros" width="90" x="45" y="30"> <list key="macros"> <parameter key="DataRoot" value="/home/jdoe/data/"/> </list> </operator> <operator activated="true" class="subprocess" expanded="true" height="76" name="Read Zd 15-25" width="90" x="45" y="120"> <process expanded="true" height="463" width="844"> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV (7)" width="90" x="112" y="30"> <description>Liest zwei CSV-Dateien ein und kombiniert die Example-Sets</description> <parameter key="file_name" value="C:\Dokumente und Einstellungen\sland\Desktop\Hadron_4000_Zd_15_25.csv"/> </operator> <operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV (8)" width="90" x="112" y="210"> <description>Liest zwei CSV-Dateien ein und kombiniert die Example-Sets</description> <parameter key="file_name" value="C:\Dokumente und Einstellungen\sland\Desktop\Gamma_4000_Zd_15_25.csv"/> </operator> <operator activated="true" class="append" expanded="true" height="94" name="Append (4)" width="90" x="315" y="30"/> <connect from_op="Read CSV (7)" from_port="output" to_op="Append (4)" to_port="example set 1"/> <connect from_op="Read CSV (8)" from_port="output" to_op="Append (4)" to_port="example set 2"/> <connect from_op="Append (4)" from_port="merged set" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Mark Id" width="90" x="185" y="120"> <parameter key="name" value="idx"/> <parameter key="target_role" value="id"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Mark Label" width="90" x="313" y="120"> <parameter key="name" value="ExpectedLabel"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="nominal_to_binominal" expanded="true" height="94" name="Nominal to Binominal" width="90" x="447" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="ExpectedLabel"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="remap_binominals" expanded="true" height="76" name="Remap Binominals" width="90" x="581" y="255"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="ExpectedLabel"/> <parameter key="include_special_attributes" value="true"/> <parameter key="negative_value" value="Gamma"/> <parameter key="positive_value" value="Hadron"/> </operator> <operator activated="true" class="naive_bayes" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="648" y="75"/> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model (2)" width="90" x="782" y="75"> <list key="application_parameters"/> </operator> <operator activated="true" breakpoints="after" class="performance_binominal_classification" expanded="true" height="76" name="Performance (2)" width="90" x="916" y="120"> <parameter key="main_criterion" value="accuracy"/> <parameter key="precision" value="true"/> <parameter key="recall" value="true"/> </operator> <connect from_op="Read Zd 15-25" from_port="out 1" to_op="Mark Id" to_port="example set input"/> <connect from_op="Mark Id" from_port="example set output" to_op="Mark Label" to_port="example set input"/> <connect from_op="Mark Label" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Remap Binominals" to_port="example set input"/> <connect from_op="Remap Binominals" from_port="example set output" to_op="Naive Bayes (2)" to_port="training set"/> <connect from_op="Naive Bayes (2)" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Naive Bayes (2)" from_port="exampleSet" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
