hi,
I have different types of data and i have to work with classification algorithm id3. This gives best trees for my work.
but some of my data can't work with id3, it's also can work with desicion tree and CHAİD algorithms.
my data is :
http://rapidshare.com/files/383023814/insan_rp.xls.htmland my process is(it's simple):
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="359" width="614">
<operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
<parameter key="repository_entry" value="//My Repository/29.04 rpler/insan"/>
<operator activated="true" class="free_memory" expanded="true" height="76" name="Free Memory" width="90" x="179" y="75"/>
<operator activated="true" class="id3" expanded="true" height="76" name="ID3" width="90" x="246" y="255"/>
<connect from_op="Retrieve" from_port="output" to_op="Free Memory" to_port="through 1"/>
<connect from_op="Free Memory" from_port="through 1" to_op="ID3" to_port="training set"/>
<connect from_op="ID3" from_port="model" to_port="result 1"/>
</process>
</process>
and this is the failure note:
Exception: java.lang.RuntimeException
Message: Cannot clone com.rapidminer.example.set.SplittedExampleSet: java.lang.reflect.InvocationTargetException. Target: java.lang.RuntimeException: Cannot clone com.rapidminer.example.set.SplittedExampleSet: java.lang.reflect.InvocationTargetException. Target: java.lang.OutOfMemoryError: Java heap space. Cause: java.lang.OutOfMemoryError: Java heap space.. Cause: java.lang.RuntimeException: Cannot clone com.rapidminer.example.set.SplittedExampleSet: java.lang.reflect.InvocationTargetException. Target: java.lang.OutOfMemoryError: Java heap space. Cause: java.lang.OutOfMemoryError: Java heap space..
Stack trace:
com.rapidminer.example.set.AbstractExampleSet.clone(AbstractExampleSet.java:390)
com.rapidminer.operator.learner.tree.TreeBuilder.buildTree(TreeBuilder.java:208)
com.rapidminer.operator.learner.tree.TreeBuilder.buildTree(TreeBuilder.java:220)
best regards.
